Trying to understand why the while loop is behaving weirdly.
HAL_MasterReceiveInterrupt() enables the control bits for I2C and continues to loop unless the STATE is READY - in other words, when the data is fully read but I see the it executing outside the while loop. So while loop shouldn't end until the the return value from the function is I2C_READY
The output looks as follows:
RXing...
Printing buffer values...
Stopping transmission
Instead of:
RXing...
Printing buffer values // now that we are outside the loop
what's up with the sequence of execution?
I2C_State HAL_MasterReceiveInterrupt(void)
    I2C_State i2cState = I2C_handle_p->I2C_State;
    if (i2cState != I2C_RX_BUSY && i2cState != I2C_TX_BUSY)
        printf ("RXing...\n");
        I2C_handle_p->I2C_State = I2C_RX_BUSY;
        GenerateStartCondition(I2C_handle_p);
        I2C_SetCtrlBits();   // enable i2c control bits
    return i2cState;
static void I2C_StopTransmission(void)
    printf ("Stopping transmission...\n\n");
    // disable control bits
    I2C_handle_p->pI2Cx->CR2 &= ~(1 << I2C_CR2_ITEVTEN_Pos);
    I2C_handle_p->pI2Cx->CR2 &= ~(1 << I2C_CR2_ITBUFEN_Pos);
    // restore struct
    I2C_handle_p->I2C_State = I2C_READY;
    I2C_handle_p->rxBufferLength = BYTES_PER_TRANSACTION;
// app.c
void ReadVal() {
  while (HAL_MasterReceiveInterrupt() != I2C_READY);
  printf ("Printing buffer values..."); // assuming I2C read operation is completed
  while(1);
Who calls the I2C_StopTransmission? But anyway, the I2C_StopTransmission sets the I2C_READY, so it shall be the last call before you execute "Printing buffer values". And HAL_MasterReceiveInterrupt changes the staus from I2C_READY to I2C_BUSY. So the sequence is as follows:
n x times
"RXing..."
"Stopping transmission..."
n x times
EDIT:
if it's not rx_busy and it's not tx_ busy then
?? then it's rx_busy??
Further, you ask a state that obviously is set by system and then you override it?
  • \$\begingroup\$ ah, so the initial value stored in i2cState is I2C_READY, hence the while loop doesn't get executed to begin with. But there's still a strange behavior that I'm not able to understand regarding getting out of the while loop even though i2cState is not I2C_READY (hence the prints). also, would it be better to add say I2C_NOTREADY so the initial value is not I2C_READY? in regards to later comment, the initial value is not expected to be either I2C_RX_BUSY or I2C_TX_BUSY \$\endgroup\$
    – xyf
    Apr 6, 2020 at 23:26
