I have two electric motors at my disposal, both equipped with KTY84-130 silicon temperature sensors (PTC thermistors). The sensors themselves are buried deep within the innards of the motors and I don't want to meddle there if not absolutely required.
I always thought these type of sensors are just temperature-dependent resistors, so polarity does not matter. Indeed, when measured with a DMM, they show the same resistance (around 620 ohms at room temp) in both directions.
However, the Curtis controller manual warns about observing proper polarity:
Moreover, after some digging in the datasheet of the KTY84 it seems they are non-symmetrical, but only above 150°C:
Question
I'm looking for some minor tell-tale sign to infer the polarity (like how you can discern between the B-E and B-C junction of a NPN - the diode drop is slightly lower for the B-E). All I have is:
- the two motors with coloured wires sticking out of them¹
- two more sensors (as through-hole parts)
- DMM/bench PSU/etc. (normal lab equipment)
How (if it's possible) can I identify the polarity?
One method (which I don't like)
I can pass current to self-heat the thermistors, but I'll have to cook them over 150°C for this method to work, and I'll very likely need to exceed the absolute maximum rating for current to achieve sufficient heating. I'll keep this as a last-resort method.
¹ and those wires don't help either; they are not even consistent between the two motors. I asked the guys who made the motors, they don't know how they installed them, they too were thinking the sensors don't have polarity.
