I'm designing a power hungry robot and this is my first time constructing a battery pack. Specifically, I am going to use a 3(series) x4(parallel) 18650 battery pack using these Samsung 35E cells. The calculated max current draw on this battery pack would come out to be 32 amps. When finding a Battery Management System, should I be looking for one with a max current rating above or below(like this one) the calculated 32 amps of the battery pack?
1 Answer
Above obviously, otherwise you restrict the power available or damage something in use.
Also make sure you have sufficient fuses.
