I'm trying to run the SSD1306 128x32 on a NUCLEO board. But I can't get the thing to properly initialize. This is my initialization sequence.
ssd1306_WriteCommand(0xAE); //display off
ssd1306_WriteCommand(0xA8); //Set MUX Ratio
ssd1306_WriteCommand(0x1F); //sets to 31
ssd1306_WriteCommand(0xD3);//Set display offset
ssd1306_WriteCommand(0x00);//no offset
ssd1306_WriteCommand(0x40 | 0x00);//Memory Start
ssd1306_WriteCommand(0xA0); //column address mapped to 127 //Start left or right
ssd1306_WriteCommand(0xC8); //COM output mode //Start top or bottum
ssd1306_WriteCommand(0xDA); //COM pin hardware configuration
ssd1306_WriteCommand(0x02); //configuration
ssd1306_WriteCommand(0x81); //contrast control
ssd1306_WriteCommand(0x7F); //set to
ssd1306_WriteCommand(0xA4); //Entire Display ON
ssd1306_WriteCommand(0xA6); //Normal/Inverse A7 for inverse
ssd1306_WriteCommand(0xD5); //set oscolation frequency
ssd1306_WriteCommand(0x01); //set to
ssd1306_WriteCommand(0x8D); //set charge pump
ssd1306_WriteCommand(0x14); //enable charge pump
ssd1306_WriteCommand(0xAF); //turn on screen
But whenever I run the this all I get is a bunch of randomly active pixels. Am I missing something?
  • \$\begingroup\$ I guess, the ssd1306_WriteCommand() is a derivative of SPI_write(), well some ssd1306 commands are more than 1 byte long, so you should use a SPI write, also check the SPI phasing. \$\endgroup\$ – Marko Buršič Apr 8 at 12:50
  • \$\begingroup\$ Random pixels may be normal. I don't see a clear command in your code. I have a slightly different OLED, it powers on with random pixels. \$\endgroup\$ – Mattman944 Apr 8 at 16:42
An example of similar OLED display, see that commands are more than one byte long.
write_reg(par, 0xFD, 0x12);
write_reg(par, 0xAE);
write_reg(par, 0xB3, 0xF3);
write_reg(par, 0xCA, 0x3F);
write_reg(par, 0xA2, 0x00);
write_reg(par, 0xA1, 0x00);
write_reg(par, 0xA0, 0x14, 0x11);
write_reg(par, 0xAB, 0x01);
write_reg(par, 0xB4, 0xA0, 0xFD);
write_reg(par, 0xC1, 0xFF);
write_reg(par, 0xC7, 0x0F);
write_reg(par, 0xB1, 0xF0);
write_reg(par, 0xD1, 0x82, 0x20);
write_reg(par, 0xBB, 0x0D);
write_reg(par, 0xBE, 0x00);
write_reg(par, 0xA6);
write_reg(par, 0xAF);
For example your code:
Should be something like this:
ssd1306_WriteCommand(0xA0, 0xC8, 0xDA );
And so, also the other commands that require operands.
| improve this answer | |
