-1
I would like to include a magnetic tunnel junction in a circuit and simulate it. Since LTspice does not have this device, I decided to model it in Verilog.
Now, I am not able to include the MTJ model (Verilog file .v) in the LTspice. Do you have any suggestion? I have surfed the net for hours but I do not manage. I have a MAC.
  • \$\begingroup\$ Exactly what kind of MTJ behavior are you trying to model in SPICE? What does the Verilog model do that you haven't been able to do with a SPICE model? \$\endgroup\$ Commented Apr 9, 2020 at 13:51
  • \$\begingroup\$ My supervisor gave me a code that I could not understand, so I decided to simulate the circuit in Matlab. Anyway I would need to simulate a tunnel barrier, so the tunnel resistance depends on the voltage. The material will be MgO. Do you have any idea/solution? thanks! \$\endgroup\$ Commented Apr 9, 2020 at 14:26
Varilog is typically used to model digital systems. Your magnetic tunnel junction, as well as your simulator, are analog systems. Are you sure you know what you're doing?
In any case, there already exists spice models for magnetic tunnel junction devices.
Here is a link: http://mtj.umn.edu/Downloads.html
  • \$\begingroup\$ I already tried those, but do not work to me. Moreover, I would like to include a tunnel junction in a circuit.. \$\endgroup\$ Commented Apr 9, 2020 at 11:20
  • \$\begingroup\$ Those files should very much be component descriptions that you use to make modules that you add to your simulated circuit. That is the usual reason for making such files, and making them public. If there is more to them, then you will probably have to look at the source and pick out the parts than interest you. \$\endgroup\$
    – Charlie
    Commented Apr 9, 2020 at 11:25
  • \$\begingroup\$ "Our self-contatined, physics-based magnetic tunnel junction (MTJ) SPICE model" Yeah... doesn't get any more obvious than this. Those are component models for magnetic tunnel junction devices. \$\endgroup\$
    – Charlie
    Commented Apr 9, 2020 at 11:30
  • \$\begingroup\$ I am very bad, I do not manage. Could you help me please if I share the screen (with compensation? If yes, you could write me down on [email protected] \$\endgroup\$ Commented Apr 9, 2020 at 12:09
  • \$\begingroup\$ I must respectfully decline. It's is almost for sure against SE guidelines to do a screen share. I recommend learning more about SPICE, and, in particular LTspcie, and how to add external models. \$\endgroup\$
    – Charlie
    Commented Apr 9, 2020 at 12:22
