In LTSpice, I am running transient simulations with input 2 parameters (Amplitude and Frequency) being swept. The initial graph of all the data looks like this:
Initial LTSPice data Obviously it is hard to tell what is going on. I would like to import the large simulation data into Matlab for analysis, where I can separate the data into individual waveforms - each corresponding to an amplitude and frequency that was swept.
I found a file online that implements the LTspice2Matlab command that imports a RAW file, however it cannot isolate each waveform as I expected. Are RAW files stored in a manner that each data point is paired with its amplitude and frequency? If so, how can I properly import this into Matlab?
Any ideas are welcome!
I believe you can convert the raw format to ASCII with ltsputil.exe. Look here for details.
