I would like to know if you have a way to call without needing a line of communication at CADENCE?
See the example in the PROTEUS software image, at the time I made the connections without needing the lines, this makes the visualization less polluted and easier to locate the components in the schematic.
I will be grateful if someone provides a link or PDF of a complete CADENCE tutorial.
  • \$\begingroup\$ It's called a net alias or net name. \$\endgroup\$
    – DKNguyen
    Apr 9, 2020 at 19:15
With most CAD systems you can attach a "net name" to a wire, and all wires with the same net name will be connected together, without actually drawing a wire between them.
Note that placing a net name should be a specific function of the program - just placing random text beside a wire will not name it.
  • \$\begingroup\$ I don't know if this was a communication failure because of the language transfer, but I mean: I want to make a wireless call using a PIN. I don't know which command or icon is connected from one end to the other without using wires. I took an example from Proteus because I know it is possible to do this. Repeat I don't want to use wires I want to use this connection model. I just can't find it in CADENCE. NOTE: it has the PIN, but in this case I realized that used to make the call in the layout, it does not occur in the schematic. \$\endgroup\$
    – LUFER
    Apr 10, 2020 at 20:09
  • \$\begingroup\$ In the CAD systems I've used, you can't put a net name directly on a component pin - you need to draw a short bit of wire, and put the net name on that. Possible language/translation problem: when you say "wireless call using PIN" I think of using a cell phone or radio to pass information, not indicating connections on a schematic. \$\endgroup\$ Apr 10, 2020 at 20:56
