Setup: ATMEL Studio 7, ASF3.47.0, SAME70 XPlained eval board.
In the minimum working example shown below, I use the onboard LED for visualizing if the timer and interrupt enabling have executed. PIO_PD20
is used to check if the interrupt is working. For that I simply connected my oscilloscope probe to MISO
on the six-pin header near the center of the board. The code below works as expected up to frequencies of 2287 Hz. Once I choose frequencies higher than that, the interrupt doesn't seem to get triggered. What am I doing wrong? I need this to clock at 100 kHz.
I've also used the debugger to step through the individual lines of code. A breakpoint in the TC0 handler gets trigger at frequencies at or below 2287 Hz. Higher frequencies do not trigger the breakpoint, reconfirming that the interrupt routine doesn't fire.
#include <asf.h>
void TC0_Handler(void) {
volatile uint32_t ul_dummy;
pio_set_output(PIOD, PIO_PD20, HIGH, DISABLE, DISABLE);
ul_dummy=TC0->TC_CHANNEL[0].TC_SR; // read status register to clear interrupt flag.
UNUSED(ul_dummy);
pio_set_output(PIOD, PIO_PD20, LOW, DISABLE, DISABLE);
int main (void) {
static uint32_t ul_sysclk, ul_div, ul_tcclks;
uint32_t interrupt_frequency=2287; // in Hz
sysclk_init();
board_init();
pmc_enable_periph_clk(ID_PIOC);
pmc_enable_periph_clk(ID_PIOD);
// Turn onboard LED off
pio_set_output(PIOC, PIO_PC8, HIGH, DISABLE, DISABLE);
// Timer and interrupt configuration
ul_sysclk=sysclk_get_cpu_hz();
pmc_enable_periph_clk(ID_TC0);
tc_find_mck_divisor(interrupt_frequency, ul_sysclk, &ul_div, &ul_tcclks, ul_sysclk);
tc_init(TC0, 0, ul_tcclks | TC_CMR_CPCTRG);
tc_write_rc(TC0, 0, (ul_sysclk/ul_div)/interrupt_frequency);
NVIC_EnableIRQ((IRQn_Type) ID_TC0);
tc_enable_interrupt(TC0, 0, TC_IER_CPCS);
tc_start(TC0, 0);
// Turn onboard LED on
pio_set_output(PIOC, PIO_PC8, LOW, DISABLE, DISABLE);
while(true){};
is 16397 (ul_sysclk
is 300000000 andul_div
is 8). If I choose 2288 Hz as interrupt frequency,(ul_sysclk/ul_div)/interrupt_frequency
is 65588 (ul_div
is 2). \$\endgroup\$tc_find_mck_divisor
. \$\endgroup\$
