I am doing a program where I am toggling an LED at a PIC24F Development Board an Explorer 16/32 development board with a PIC24FJ1024GB610 microcontroller attached to it.
Explorer 16/32 got an LED (D3) connected to pin P17, which corresponds to PORTA RA0
The program consists of configuring the clock signal (oscillator source), setting up the 16-bit Timer 1, and initializing the digital output (TRISAbits.TRISA0 = 0
CLOCK
- The clock signal is sourced from OSCFDIV
#pragma config FNOSC = OSCFDIV
- the Prescaler block got its oscillator source from the FRC (Fast Internal RC oscillator)
CLKDIVbits.RCDIV = FRC
. The FRC got a frequency of 8MHz - Set the Prescaler to 1/4
OSCDIV = 4
where Foscdiv = 2MHz - After the Fosc is divided by 2 by the Postscalar, we shall have Fcy = 1MHz, or Tcy = 1us
The diagram below illustrates how the oscillator was chosen.
TIMER
Timer 1 is a 16 bit Timer.
I have configured the timer's clock signal to be sourced internally (Tcy = 1us).
t = count * Tcy, if t = 50 ms = 50000 us, Tcy = 1 us, then count = 50000
By the logic of the code, when TMR1 = 50000 (50 ms), T1IF will be set then T1IF will be cleared by SW, and LATAbits.LATA0
(LED0
) will be toggled, giving us a square wave with Time Period = 100ms.
This is the code of my application
#pragma config FWDTEN = OFF//disable WDT timer
#pragma config ICS = PGD2//allow debugging
#pragma config FNOSC = OSCFDIV//COSC = OSCFDIV
#include "xc.h"
I would like to make a pin toggle
* initialize the clock
* fcy = 1MHz, Tcy = 1us
* RA0 will toggle every 50 ms
* hence we get a square pulse of T = 100 ms
#define TMR1_IF IFS0bits.T1IF
#define LED0 LATAbits.LATA0
#define FIFTY_MS 50000
#define FRC (0b000)
void digital_setup (void);
void timer_setup (void);
void clock_setup (void);
int main(void)
clock_setup ();
digital_setup ();
timer_setup ();
while(1)
if(TMR1_IF == 1)//if Timer 1 Interrupt Flag is set
TMR1_IF = 0;//clear IF
LED0 = ~LED0;//toggle PORTA RA0 (P17)
return 0;
//output RA0
TRISAbits.TRISA0 = 0;//digital
CLKDIVbits.RCDIV = FRC;
OSCDIV = 4;
PR1 = FIFTY_MS;
T1CONbits.TCS = 0;//cs internal
T1CONbits.TGATE = 0;//gate don't accumulate
T1CONbits.TON = 1;//start timer
However, when I compiled and programmed the code into my development board, I got a square wave with twice the timer period (200 ms)
Not sure if this is related, but I tried debugging it, and when I change the value of TMR1 to 50000, the T1IF
bit doesn't get set.
Can someone tell me why I am getting a square wave with twice the period. Any help would be appreciated
