I have the following problem.
Consider the circuit below, where the bottom of the arrow is the +-pole of the voltage drop:
What resistor value for \$R_2\$ gives a damping factor of \$d=0.9\$ for the filter transfer function \$\frac{V_{out}}{V_{in}}\$.
Okay so first thought is to find the transfer function. We can write a node equation for \$V_{out}\$.
\$ \frac{V_{out}}{R_2}+\frac{V_{out}}{600 \Omega}+\frac{V_{out}}{330 \text{nF}}+\frac{V_{out}-V_{in} }{5.1 \text{uH}} =0\$
Rearranging this equation with Maple gives me following transfer function.
\$ \frac{V_{out}}{V_{in}}=\frac{196080 \cdot R_2}{1+3.22638\cdot 10^6 \cdot R_2}\$
But from here I'm kind of stuck, since I don't know where to go. However, I have these equations from my notes that might help me.
\$ d=\frac{1}{Q_{factor}} \$
\$ B_{bandwidth}=\frac{f_c}{Q_{factor}} \$
Where \$ f_c\$ is the resonance frequency.
I hope someone can help me with this.
The transfer function of this circuit can be found in two simple ways: an impedance divider where you write that \$\frac{V_{out}}{V_{in}}=\frac{{\frac{1}{sC_2}||R_{eq}}}{\frac{1}{sC_2}||R_{eq}+sL_1}\$ and you develop this expression. Or you can use the fast analytical techniques or FACTs described in the book I wrote and obtain the transfer function in a few steps, without writing a line of algebra. 5 small sketches is all you need in which you determine the resistance \$R\$ driving the capacitor or the inductor when the source is zeroed (replaced by a short circuit). \$R_{eq}\$ is the equivalent resistance made of the existing 600-\$\Omega\$ already in place and the one you will parallel with it:
Assemble the time constants as in the below sheet and you have the transfer function:
Now, how do obtain the resistance you want? The thing is to re-write the transfer function in the normalized second-order form which is: \$H(s)=\frac{1}{1+\frac{s}{\omega_0Q}+(\frac{s}{\omega_0})^2}\$. Then, you identify the variables between this expression and the one we have determined to link the equivalent resistance and the quality factor \$Q\$ you want (or damping ratio \$\zeta\$ since the two are linked):
And if you do the maths, you find a resistance of 2.192 \$\Omega\$ needs to be paralleled with the 600-\$\Omega\$ one to obtain the wanted damping ratio.
For a parallel R and C, quality factor is: -
$$Q = R\sqrt{\dfrac{C}{L}}$$
And damping ratio \$\zeta\$ is $$\dfrac{1}{2Q}$$
All formulas from this wiki page.
If you want an interactive tool that gives you the numbers try this. It tells me that to obtain a damping ratio of 0.9 requires a resistor of value 2.2 ohms: -
Solving the TF (assuming one resistor called R)
$$H(s) = \dfrac{R||X_C}{X_L + R||X_C} = \dfrac{\frac{R}{sC}}{sL(R + \frac{1}{sC})+ \frac{R}{sC}} = \dfrac{R}{s^2RLC +sL + R}$$
At this point you re-arrange to try and fit into the standard equation for a 2nd order low pass filter. Standard equation that I use is this: -
$$H(s) = \dfrac{\omega_n^2}{s^2 +s2\zeta\omega_n + \omega_n^2}$$
So, dividing the original equation's numerator and denominator by RLC gives this: -
$$H(s) = \dfrac{\frac{1}{LC}}{s^2 + \frac{s}{RC} +\frac{1}{LC}}$$
Hence \$\omega_n = \dfrac{1}{\sqrt{LC}}\$ and \$2\zeta\omega_n = \dfrac{1}{CR}\$.
If you rearrange things you get this: -
$$2\zeta = \dfrac{\sqrt{LC}}{RC} = \dfrac{1}{Q}$$
Hence: -
$$Q = R\sqrt{\frac{C}{L}}$$
  • \$\begingroup\$ Thank you for the very quick answer but I'm still uncertain. That formula you mention, \$ Q = R \sqrt{\frac{C}{L}}\$ how does this work when they are two resistors, and not just one? And does this involve the transfer function at all? \$\endgroup\$
    – Carl
    Apr 12, 2020 at 19:15
  • \$\begingroup\$ Just regard the two resistors as being in parallel. However 600 ohm in parallel with 2.2 ohms is still largely 2.2 ohms. \$\endgroup\$
    Apr 12, 2020 at 19:27
  • \$\begingroup\$ Oh right I see. But if I want to be most precise I should write: \$Q=\frac{600 \Omega \cdot R_2}{600 \Omega + R_2} \sqrt{\frac{C}{L}}\$. Coupled with the other formula \$ d = \frac{1}{2Q} \$ I can find d. Am I on the right track? And can I simply just ignore the transfer function, even though it was mentioned in the problem statement? That was actually the part that gave me the most trouble. \$\endgroup\$
    – Carl
    Apr 12, 2020 at 19:31
  • \$\begingroup\$ Solving the transfer function will get you the same answer as what I have written but, you need some skills with manipulating Laplace transforms to do that. The other formulas are correct if I assume d is zeta. \$\endgroup\$
    Apr 12, 2020 at 20:30
