So I assume the answer is no but want to be 100% sure.
I will already have a pulldown resistor on the inverter input, the output is connected to 555 timer trigger input (it triggers on falling edge), typically when a transistor or switch is used to pull the trigger input to ground a pullup resistor is needed.
Will the inverter hold the input high at Vcc?
