I'm attempting to build a 4-bit modulo-10 down-counter (i.e 9,8,7...,1,0,9,8,7...0). Here is my code so far:
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.NUMERIC_STD.ALL;
ENTITY downcounter is
PORT (
    enable  : in std_logic;
    reset   : in std_logic;
    clk     : in std_logic;
    count   : out std_logic_vector(3 downto 0));
END downcounter;
ARCHITECTURE Behavior OF downcounter IS
COMPONENT Tflipflop
PORT (
    clk   : in std_logic;
    T     : in std_logic;
    Q     : out std_logic);
ENDCOMPONENT;
SIGNAL Q0 : std_logic := '1';
SIGNAL Q1 : std_logic := '0';
SIGNAL Q2 : std_logic := '0';
SIGNAL Q3 : std_logic := '1';
SIGNAL TFF2IN : std_logic;
SIGNAL TFF3IN : std_logic;
SIGNAL TFF4IN : std_logic;
BEGIN
TFF1: Tflipflop PORT MAP (clk, enable, Q0);
TFF2IN <= (NOT Q0) AND enable;
TFF2: Tflipflop PORT MAP (clk, TFF2IN, Q1);
TFF3IN <= (NOT Q1) AND TFF2IN;
TFF3: Tflipflop PORT MAP (clk, TFF3IN, Q2);
TFF4IN <= (NOT Q2) AND TFF3IN;
TFF4: Tflipflop PORT MAP (clk, TFF4IN, Q3);
PROCESS (clk)
BEGIN
    IF FALLING_EDGE(clk) THEN
        IF reset = '0' OR (Q3='1' AND Q1='1') OR (Q3='1' AND Q2='1') THEN
            count <= "1001";
        ELSE
            count <= Q3 & Q2 & Q1 & Q0;
        END IF;
    END IF;
END PROCESS;
END Behavior;
I'm currently testing it in model-sim, but I'm getting this weird behavior: enter image description here
The counter works from 9 to 0, but then when it reaches 9 again, it just stops there. Then after the same amount of time each time, it begins to work again!
I've tried my best to figure it out but I just can't. Any help is appreciated!
Edit: if a schematic helps, I'm basically doing this: enter image description here except the enable is connected and AND-ed with each input of each T Flip Flop.
  • \$\begingroup\$ To debug a circuit like this, you can't just look at the top-level signals. You have to go down into the hierarchy and add internal signals to your waveform. Then you can see what is all happening. \$\endgroup\$ – Oldfart Apr 13 '20 at 7:21
    \$\begingroup\$ It's doing what you asked it. \$\endgroup\$ – user_1818839 Apr 13 '20 at 10:43
  • \$\begingroup\$ @BrianDrummond After your remark I suddenly noticed the error. \$\endgroup\$ – Oldfart Apr 13 '20 at 12:15
  • \$\begingroup\$ @BrianDrummond how? \$\endgroup\$ – Sami Jr Apr 13 '20 at 22:10
    \$\begingroup\$ You're asking the counter (Q3..Q0) to keep counting until it rolls over at 15, while holding the output (confusingly, called "count") at 9. \$\endgroup\$ – user_1818839 Apr 13 '20 at 22:21
