I think some logic IC input can handle a range of lower voltage levels but will output at supply voltage...
What is the best way to achieve an input that can handle higher levels but output at a lower level for the next stage? Some logic ICs or circuits that can do this?
not dealing with high speeds, 5kHz max.
5v logic with 5-10V input range
What about a zener on the input?
