I'm trying to program my school learning board with PIC16F88 on Ubuntu. I installed sdcc and picpgm.
PIC16F88 already has bootloader so I intended to compile C code in to HEX with sdcc and then upload it with picpgm. We used microC's microBootloader tool in school.
So I tried to compile first and got to the first problem: when I call
$ sdcc -mpic16f88 lucke.c
I got:
at 1: error 131: cannot generate code for target 'pic16f88'
Did I think in the right direction at all? This is my first time with programming chips.
  • \$\begingroup\$ Where should I ask then? \$\endgroup\$ – Andrej Nov 19 '12 at 19:52
  • \$\begingroup\$ Flagged for migration to StackOverflow.SE \$\endgroup\$ – Andrew Nov 20 '12 at 7:42
  • \$\begingroup\$ @Andrej: Don't get discouraged by these comments, it is just the Stackexchange way of keeping questions organized. \$\endgroup\$ – jippie Nov 20 '12 at 8:02
Use -mpic16 at the command line.
  • \$\begingroup\$ Thanks, it is a step forward but I get errors: lucke.c:25: warning 112: function 'Delay_ms' implicit declaration and lucke.c:25: error 101: too many parameters \$\endgroup\$ – Andrej Nov 19 '12 at 20:37
    \$\begingroup\$ Entirely unrelated to this question. Register a new question and copy in the source code you are trying to compile. \$\endgroup\$ – jippie Nov 19 '12 at 20:42
