I'm working with I2C and I have been using python library to communicate with a magnetic sensor. Now I am working with a different chip and it makes me wonder if I get the right concept or not. The only difference in new chip is that the register values are 2bytes.
Suppose
Chip address is 0x30, register address is 0x11 and data that I want to write is 0x22
This is how i2c works To write to register address: - write(chip address, register address) - write(chip address, data)
This is how i2c works To read from Register: - write(chip address, register address) - Read(chip address, No of bytes)
Please correct me if I'm wrong.
I've been using a python library quick2wire for this. In this library we can use a function called writing_bytes(chip address, register address, data)
How does it decide which is register address and which is data?
If the chip's register address is 2bytes, it will set pointer to address+data in writing_bytes function?
