So with my one of the part of my circuit below, I only wanted to see the effect on the op amp if I changed the input voltage (knowing that the inverting input is 0). My first thought was that even if I changed the input voltage, the output would changed accordingly so that the amplifier gain stays the same (since it's the same op amp).
So I first set my input voltage as 7V and found the output voltage was 8.5V. Then I changed my input to 14V (double of the initial input) and found out that the output voltage was still 8.5 Volts. Now I am totally lost since my initial hypothesis is wrong.
Can someone guide me on where I was wrong?
