I am trying to design a 3-bit counter circuit with jk flip flops that count from 0 to 7 with a clock signal and remain constant at 7 until reset. Counter counts well but it stops at six not seven.
Can you guys help me please.
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityI am trying to design a 3-bit counter circuit with jk flip flops that count from 0 to 7 with a clock signal and remain constant at 7 until reset. Counter counts well but it stops at six not seven.
You're asynchronously resetting your first FF when you get to seven. As soon as you're at 6 and flip to 7, the output of U4A resets bit 0, and you go back to 6. Disconnect U1 pin 3 (or tie high, but I note you're not driving the other set/reset lines, so I assume it's TTL or has internal pullups). Then it'll work the way you want.
