I am using a load cell that is wired to a HX711 amp in the following manner: Wiring schematic I used to connect my load cell to my arduino. I have been attempting to use the calibration example code that is included in the HX711_ADC library (code listed bellow). After using the code to generate a calibration factor, the correct weight of the object used should be displayed in the serial port. When I do this the weight displayed either increases or decreases quickly. The absolute values of the outputs increase when more weight is applied and decrease when weight is removed but the outputs still increase or decrease on their own. I have tried other libraries as well and other methods of obtaining calibration factors but the same thing still happens.
#include <HX711_ADC.h>
#include <EEPROM.h>
//HX711 constructor (dout pin, sck pin):
HX711_ADC LoadCell(4, 5);
int eepromAdress = 0;
long t;
void calibrate() {
  Serial.println("***");
  Serial.println("Start calibration:");
  Serial.println("It is assumed that the mcu was started with no load applied to the load cell.");
  Serial.println("Now, place your known mass on the loadcell,");
  Serial.println("then send the weight of this mass (i.e. 100.0) from serial monitor.");
  float m = 0;
  boolean f = 0;
  while (f == 0) {
    LoadCell.update();
    if (Serial.available() > 0) {
      m = Serial.parseFloat();
      if (m != 0) {
        Serial.print("Known mass is: ");
        Serial.println(m);
        f = 1;
      else {
        Serial.println("Invalid value");
  float c = LoadCell.getData() / m;
  LoadCell.setCalFactor(c);
  Serial.print("Calculated calibration value is: ");
  Serial.print(c);
  Serial.println(", use this in your project sketch");
  f = 0;
  Serial.print("Save this value to EEPROM adress ");
  Serial.print(eepromAdress);
  Serial.println("? y/n");
  while (f == 0) {
      char inByte = Serial.read();
      if (inByte == 'y') {
        #if defined(ESP8266)
        EEPROM.begin(512);
        #endif
        EEPROM.put(eepromAdress, c);
        EEPROM.commit();
        #endif
        EEPROM.get(eepromAdress, c);
        Serial.print("Value ");
        Serial.print(c);
        Serial.print(" saved to EEPROM address: ");
        Serial.println(eepromAdress);
        f = 1;
      else if (inByte == 'n') {
        Serial.println("Value not saved to EEPROM");
        f = 1;
  Serial.println("End calibration");
  Serial.println("For manual edit, send 'c' from serial monitor");
void changeSavedCalFactor() {
  float c = LoadCell.getCalFactor();
  boolean f = 0;
  Serial.print("Current value is: ");
  Serial.println(c);
  Serial.println("Now, send the new value from serial monitor, i.e. 696.0");
  while (f == 0) {
      c = Serial.parseFloat();
      if (c != 0) {
        Serial.print("New calibration value is: ");
        Serial.println(c);
        f = 1;
      else {
        Serial.println("Invalid value, exit");
        return;
  f = 0;
  while (f == 0) {
        EEPROM.begin(512);
        #endif
        EEPROM.commit();
        #endif
        Serial.print(c);
        f = 1;
        f = 1;
  Serial.println("End change calibration value");
void setup() {
  Serial.begin(9600); delay(10);
  Serial.println();
  Serial.println("Starting...");
  LoadCell.begin();
  long stabilisingtime = 2000; // tare preciscion can be improved by adding a few seconds of stabilising time
  LoadCell.start(stabilisingtime);
  if (LoadCell.getTareTimeoutFlag()) {
    Serial.println("Tare timeout, check MCU>HX711 wiring and pin designations");
  else {
    LoadCell.setCalFactor(1.0); // user set calibration value (float)
    Serial.println("Startup + tare is complete");
  while (!LoadCell.update());
  calibrate();
void loop() {
  //update() should be called at least as often as HX711 sample rate; >10Hz@10SPS, >80Hz@80SPS
  //longer delay in sketch will reduce effective sample rate (be carefull with delay() in the loop)
  LoadCell.update();
  //get smoothed value from the data set
  if (millis() > t + 250) {
    float i = LoadCell.getData();
    Serial.print("Load_cell output val: ");
    Serial.println(i);
    t = millis();
  //receive from serial terminal
    float i;
    if (inByte == 't') LoadCell.tareNoDelay();
    else if (inByte == 'c') changeSavedCalFactor();
  //check if last tare operation is complete
  if (LoadCell.getTareStatus() == true) {
    Serial.println("Tare complete");
***** UPDATE******* I changed the code so that the main loop only printed the value that the scale was reading, as shown bellow. The same problem still occurs. The scale output continually increases or decreases. At one point I let it run for about 4 minutes and observed the outputs. It will increase continuously but slowly, and sometimes it switches to decreasing. I noticed that it responds to removing and adding weight. Sometimes when I remove and then add weight, the output stabilizes for about 10 seconds before beginning to increase/decrease.
#include <EEPROM.h>
long t;
void calibrate() {
  float m = 0;
  boolean f = 0;
  while (f == 0) {
    LoadCell.update();
      if (m != 0) {
        Serial.println(m);
        f = 1;
      else {
  Serial.print(c);
  f = 0;
  while (f == 0) {
        EEPROM.begin(512);
        #endif
        EEPROM.commit();
        #endif
        Serial.print(c);
        f = 1;
        f = 1;
  boolean f = 0;
  Serial.println(c);
  while (f == 0) {
      if (c != 0) {
        Serial.println(c);
        f = 1;
      else {
        return;
  f = 0;
  while (f == 0) {
        EEPROM.begin(512);
        #endif
        EEPROM.commit();
        #endif
        Serial.print(c);
        f = 1;
        f = 1;
void setup() {
  Serial.println();
  LoadCell.begin();
  else {
  calibrate();
void loop() {
  LoadCell.update();
  Serial.println(i);
    \$\begingroup\$ The first thing to do is make a copy of your code, strip out everything from the main loop except LoadCell.update(); and the serial print routine. Just print out the raw scales value. If it stays the same then you have a code problem. If it drifts continuously then you have a hardware problem. Edit the question with the results. \$\endgroup\$ – Transistor Apr 14 '20 at 19:53
    \$\begingroup\$ Please also provide a link to the datasheet for the load cell and the HX module. A proper schematic diagram would also be more helpful than the Fritzing diagram. \$\endgroup\$ – Elliot Alderson Apr 14 '20 at 20:21
    \$\begingroup\$ "It will increase continuously but slowly, and sometimes it switches to decreasing" - Drift is normal. Perhaps your setup has excessive drift, but we can't tell because you haven't provided any numbers. The resistance bridge is very sensitive, and can be affected by component temperature coefficients, poor connections, varying power supply voltage etc. A photo of your setup might help to pinpoint possible issues. \$\endgroup\$ – Bruce Abbott Apr 14 '20 at 23:55
    \$\begingroup\$ What are you using for calibration weights and what weight range are you calibrating over? \$\endgroup\$ – haresfur Apr 15 '20 at 3:54
