The graph as drawn is incorrect, or at least is only correct if we assume a switch in the circuit as well, being closed at wt=pi/2.
It's convenient when dealing with real world AC waveforms to split it into two parts, the initial transient, and the long term behaviour. The author is unfortunately ignoring the initial transient, and plotting the steady state current, which does not match the voltage waveform shown.
He could have saved you much confusion by simply starting his graph at the peak of the signal, V=cos(t). Then the initial transient would have been zero, and so could safely have been ignored.
Plotting the initial transient and the long term behaviour separately gives you this
The total voltage is in purple, sin(wt), starting from 0. This is what's shown in your diagram as the voltage.
We can split out the yellow curve, Vss for steady state, which starts at pi/2, when the voltage is at its peak, when we close our switch. You can see the green Iss current waveform rising quickly when the voltage is high, staying level when the voltage is zero, and falling when the voltage is negative. This is the current waveform drawn in your diagram. Crucially, at the next voltage peak at 5pi/2, the current has returned to zero. The voltage and current waveforms continue repeating every 2pi from here. They both have an average of zero.
What your diagram ignores is the initial voltage Vi in dark blue, the bit from wt=0 to pi/2. As it's positive, the initial current Ii, orange waveform, increases from t=0. At pi/2 when I throw my switch, Vi goes to zero, and Ii now continues indefinitely at the same value. Because there is no resistance in the circuit, there is no voltage drop across any resistance to reduce the current. Note that in a real circuit, there would be some resistance, and this initial transient current would die away to zero, with a time constant of L/R.
Finally we can add the partial solutions together to get the final result, Vtotal = Vi + Vss, and Itotal = Ii + Iss.
You'll note the total current is oscillatory, but has a a positive offset. In the real world, this offset would decay due to finite resistance. In the ideal world of your diagram, this initial transient persists indefinitely, as it would in a superconductor.
This diagram illustrates quite nicely why transformers and inductors have an 'inrush' current and need time delay fuses. The 'design' current of an inductor or transformer primary will be the green Iss curve. You'll notice that the peak of the light blue Itotal curve is twice the Iss peak, which usually exceeds the saturation current of the core, leading to a dramatic loss of inductance, and so a large further increase in current.
You may think that both the Iss and the Itotal curves continue indefinitely, and you'd be right. So why are we splitting out a transient and a steady state case? The answer is that in the real world, resistance causes the initial transient to decay, and so eventually at large t, regardless of the switch-on phase which determines the transient, the transient decays away and all current curves end up as the Iss curve.
