In problems determining the polarization of an antenna array I've looked at, the polarization of the total array is determined by finding the polarization of a single element and then extrapolating that polarization to the whole array?
I'm not sure why this can be done. Is it because the elements in an array are all parallel to each other so the polarization would be the same?
