It is largely said that large voltage or current variation according to the time produces EMI. (Electromagnetic interference). When drawing the layout, care have to be taken on traces with high : $$\frac{dVoltage(t)}{dt}$$ and $$\frac{dCurrent(t)}{dt}$$.
Nevertheless I do not understand this principle. I do not know what is the relation between the current or voltage variation and magnetic or electric field. On the other hand, I can understand that large variation will lead to produce a lot of harmonics at high frequencies according to Fourier's theory. And so as the PCB are made smaller and smaller, the propagation will be easier as an antenna is perfectly transmitting/receiving when this length is equal to (if I remember correctly) to the waveform lenght divided by two.
Nevertheless, I do not know a formula which tells that the amplitude of the magnetic or electric field is higher if there is large current or voltage variation. The amplitude of the magnetic field or electric field space depends mainly on the current amplitude or voltage amplitude (and the distance).
So why no attention is paid on traces with high current or high voltage ?
If there is a formula which links voltage/current variation to magnetic/electric field, please let me know :D
Thank you for your help !
