Hi everyone and apologies if this is a really dumb question.
I'm following this to control the GPIO on a raspberry PI: Circuit Diagram
I bought a starter kit which has 2 mini push buttons, but I've no idea if they can be used?
breadboard
If not there's nowhere round here I can buy a switch so it'll be a day or two, is there any way to DIY a suitable switch?
Any help would be great and sorry about the question. You're probably sick of raspberry pi questions but I have no one to ask.
  • \$\begingroup\$ That looks like a suitable momentary switch, assuming that it's normally-open. \$\endgroup\$
    – pjc50
    Nov 20, 2012 at 16:03
  • \$\begingroup\$ Don't forget the key-bounce! \$\endgroup\$
    – Tony Ennis
    Nov 20, 2012 at 16:04
  • \$\begingroup\$ @pjc50 this is where I sound really stupid - the switch they use has 2 connectors, where the one I have has 4. I don't know what to do with it... \$\endgroup\$
    – noeleo
    Nov 20, 2012 at 16:08
    \$\begingroup\$ "You're probably sick of raspberry pi questions but I have no one to ask." -- I bet raspberrypi.stackexchange.com isn't sick of them. \$\endgroup\$
    – Jim Paris
    Nov 20, 2012 at 17:59
It should work. They have 4 pins for structural strength, since they are meant to be soldered on a pcb. It has two pairs of pins, where each pin in a pair is electrically connected to the other, as illustrated in the following diagram (taken from google images):
As you can see, pins 1 & 2 are connected, and so are 3 & 4.
If it is normally closed instead of normally open, you can still make it work as expected by tweaking the software (may be as simple as inverting the logic).
  • \$\begingroup\$ ahh, thankyou I'll look into that \$\endgroup\$
    – noeleo
    Nov 20, 2012 at 18:52
You can get a button like that from Radio Shack for a buck or two. There's nothing magic about it. The mini buttons look momentary. Wire one up to an LED and see.
