I have a project in which I have a 5v RF signal pulse (cut to 3.3v using 3.3v regulator) going through a transistor (2n2222) acting as a switch to send power to a 3.3v latching relay.
I also have a ESP8266-12e (Blynk ESP) connected to a Blynk app. When the button on the app is tapped it turns on the D5 pin on the ESP. This send a 3.3v 12mA pulse to the same transistor to activate the 3.3v latching relay. The RF is coming from a remote sensor that when certain conditions are met send a signal to the main unit I am having problems with. The Blynk app allows for remote access to the main unit. When the latching relay is SET by either the RF or Blynk ESP signal it turns off the Blynk ESP, and turns on another ESP8266-12e (Reset ESP). The Reset ESP connects to the internet and sends some info to Thingspeak and then turns on its D5 pin which is connected to the RESET pin on the latching relay. The Reset ESP is then turned off stoping transmission to ThingSpeak, and turning back on the Blynk ESP so the device can be access remotely again. My problem arrises when I try to use the Blynk ESP to activate the latching relay. If I run it through the 3.3v regulator the first time I tap the Blynk app button the relay tries to engage but fails and the Blynk ESP restarts. After about 10 seconds when I tap the Blynk app button again the relay engages and the Blynk ESP turns off, the Reset ESP starts up and does it thing and then RESETs the relay.
When I use the RF signal in this set up everything thing goes well. I have tried to rewire the Blynk ESP to bypass the 3.3v regulator since it only put out a 3.3v pulse I thought it didn't have enough power to go through the regulator and effect the transistor. (But then why does it work the second time?) Anyway when I did this the relay was activated the first time, turning off Blynk ESP and on the Reset ESP.
However now when the ESP activates its D5 pin to RESET the relay it isn't successful and it starts over sometimes looping several times. I have tried to put a 9K resistor in the Blynk ESP line to the transistor and this seems to have helped. Sometimes the Reset ESP activates the relay the first time and sometimes it takes two to three loops but it always resets. I am at a loss as to why this is happening and need some creative problem solving and guidance to figure this out. I am posting the code for the Blynk ESP and the Reset ESP and the schematic for the main unit. I have included some of the main wiring routes and some power consumption/output on the schematic. If you need more information I will try to get it.
Looking up the power out from the AD1 pin on the HT12D is 1.6mA @5vdc.
THIS IS THE CODE FOR THE RESET ESP
#include <ESP8266WiFi.h>
//NEW AUTOCONNECT
#include <FS.h>         //https://github.com/esp8266/Arduino
#include <EEPROM.h>
//needed for library
#include <DNSServer.h>
#include <ESP8266WebServer.h>
#include <WiFiManager.h>         //https://github.com/tzapu/WiFiManager
#include <ArduinoJson.h>
//END NEW AUTOCONNECT
//String apiKey = "8RXVFOW83KRZHSNL"; pool filler
//const char* ssid = "Gary's Wi-Fi Network";
//const char* password = "Homenetwork";
const char* server = "api.thingspeak.com";
//NEW AUTOCONNECT
const byte numChars = 32;
char receivedChars[numChars];
char tempChars[numChars];
char Password[36]="";
char apiKey[16]="";
char apiKey2[16]="";
char channelKey[16];
String channelKey2= "&";
//DHTesp dht;
//DHTesp dht2;
//DHTesp dht3;
 WiFiClient client;
//NEW AUTOCONNECT
char defaultHost[100] = "";  //Thing Speak IP address (sometime the web address causes issues with ESP's :/
    long itt = 500;
const byte wifiResetPin = 13;
int interruptPinDebounce = 0;
long debouncing_time = 1000;
volatile unsigned long wifiResetLastMillis = 0;
bool shouldSaveConfig = false;
int address = 0;
byte value;
void saveConfigCallback () {
  Serial.println("Should save config");
  shouldSaveConfig = true;}
  void handleWifiReset(){
    if(millis()<wifiResetLastMillis){
      wifiResetLastMillis = millis();
    if((millis() - wifiResetLastMillis)>= debouncing_time){
      Serial.println("Clearing WiFi data resetting");
      WiFiManager wifiManager;
      wifiManager.resetSettings();
      SPIFFS.format();
      ESP.reset();
      delay(1000);
int addr = 0;
void setup() {
pinMode(D5,OUTPUT);
digitalWrite(D5,LOW);
  //NEW AUTOCONNECT
    // put your setup code here, to run once:
    pinMode(wifiResetPin, INPUT_PULLUP);
    attachInterrupt(digitalPinToInterrupt(wifiResetPin), handleWifiReset,FALLING);
 WiFiManagerParameter customAPIKey("apiKey", "ThingSpeakWriteAPI", apiKey, 16);
  WiFiManagerParameter customAPIKey2("channelKey", "ThingSpeakChannel Number", channelKey, 16);
//END NEW STUFF
    //WiFiManager
    //Local intialization. Once its business is done, there is no need to keep it around
   //WiFiManager wifiManager;
    //NEW STUFF START
    //wifiManager.setSaveConfigCallback(saveConfigCallback);
    wifiManager.addParameter(&customAPIKey);
    wifiManager.addParameter(&customAPIKey2);
     //END NEW STUFF
    //reset saved settings
 //wifiManager.resetSettings();
    //set custom ip for portal
    //wifiManager.setAPStaticIPConfig(IPAddress(10,0,1,1), IPAddress(10,0,1,1), IPAddress(255,255,255,0));
    //fetches ssid and pass from eeprom and tries to connect
    //if it does not connect it starts an access point with the specified name
    //here  "AutoConnectAP"
    //and goes into a blocking loop awaiting configuration
    wifiManager.autoConnect("FloWT1");
    Serial.println("Connected");
  //NEW STUFF START
  strcpy(apiKey, customAPIKey.getValue());
  strcpy(channelKey, customAPIKey2.getValue());
 String chan = String(channelKey);
  if (shouldSaveConfig) {
    Serial.println("saving config");
    DynamicJsonBuffer jsonBuffer;
    JsonObject& json = jsonBuffer.createObject();
    json["defaultHost"] = defaultHost;
    json["apiKey"] = apiKey;
    Serial.println("API");
    Serial.println("CHANNEL");
    Serial.print(apiKey);
    Serial.print(channelKey);
    String(apiKey2) = String(apiKey);
    File configFile = SPIFFS.open("/config.json", "w");
    if (!configFile) {
      Serial.println("failed to open config file for writing");
json.printTo(configFile);
    json.printTo(Serial);
    delay(1000);
    configFile.close();
    //end save
  Serial.println("local ip");
  Serial.println(WiFi.localIP());
  //END NEW STUFF
  strcpy(apiKey,customAPIKey.getValue());
  strcpy(channelKey,customAPIKey2.getValue());
 String( apiKey2) = String (apiKey);
  Serial.println("apiKEY");
   EEPROM.begin(512);  //Initialize EEPROM
  EEPROM.write(addr, 'A');    //Write character A
  addr++;                      //Increment address
  EEPROM.write(addr, 'B');    //Write character A
  EEPROM.write(addr, 'C');    //Write character A
 Serial.print(addr,'A');
  //Write string to eeprom
  String uuu = channelKey;
 String www =  apiKey2 + uuu;
  Serial.print (www);
  for(int i=0;i<www.length();i++) //loop upto string lenght www.length() returns length of string
    EEPROM.write(0x0F+i,www[i]); //Write one by one with starting address of 0x0F
  EEPROM.commit();
  //Read string from eeprom
    Serial.begin(115200);
void loop() {
  itt = 0;
  Serial.println("input");
  Serial.print(itt);
  delay(1000);
if (WiFi.status() == WL_DISCONNECTED) {
 delay(30000);}
 if (WiFi.status() == WL_CONNECTED) {  Serial.println("Connected");
delay(1000);
WiFiClient client;
char defaultHost[100] = "api.thingspeak.com";
    EEPROM.begin(512);
    Serial.println("WHAT"); //Goto next line, as ESP sends some garbage when you reset it
  Serial.print(char(EEPROM.read(addr)));    //Read from address 0x00
  Serial.print(char(EEPROM.read(addr)));    //Read from address 0x01
  Serial.println(char(EEPROM.read(addr)));    //Read from address 0x02
  Serial.println(char(EEPROM.read(addr)));    //Read from address 0x03
  String www;
  //Here we dont know how many bytes to read it is better practice to use some terminating character
  //Lets do it manually www.circuits4you.com  total length is 20 characters
  for(int i=0;i<16;i++)
    www = www + char(EEPROM.read(0x0F+i)); //Read one by one with starting address of 0x0F
  String uuu;
  for(int i=31;i<32;i++)
  {uuu =  uuu + char(EEPROM.read(0x0+i));
 Serial.println("this");
  Serial.print(www);  //Print the text on serial monitor
  Serial.println("that");
   Serial.print(uuu);
    String one = "&";
 String two = one + "field";
 String three = two + uuu;
 String four = three + "=";
  channelKey2 = four;
  delay(1000);
 Serial.print(channelKey2);
    if (client.connect(server, 80)) {
      Serial.println("hi");
    String postStr = apiKey;
    Serial.print( postStr);
    postStr += channelKey2;
    postStr += String(itt);
    Serial.print(postStr);
    //postStr += "&field4=";
    //postStr += String(f2);
    //postStr += "&field5=";
    //postStr += String(f3);
    postStr += "\r\n\r\n";
Serial.println("NOW");
Serial.print(www);
Serial.println("THEN");
Serial.print(uuu);
    client.print("POST /update HTTP/1.1\n");
    client.print("Host: api.thingspeak.com\n");
    client.print("Connection: close\n");
    client.print("X-THINGSPEAKAPIKEY: "+String (www) + "\n");
    client.print("Content-Type: application/x-www-form-urlencoded\n");
    client.print("Content-Length: ");
    client.print(postStr.length());
    client.print("\n\n\n");
    client.print(postStr);
    Serial.println("Sending data to Thingspeak");
  delay(1000);
   client.stop();
   delay(7000);
  digitalWrite(D5,HIGH);
  Serial.println("d5HIGH");
  delay(200);
  Serial.println("Waiting 20 secs");
  // thingspeak needs at least a 15 sec delay between updates
  // 20 seconds to be safe
THIS IS THE CODE FOR THE BLYNK ESP
#define BLYNK_PRINT Serial
//NodeMCU 1.0 (ESP-12E Module constant connect)
#include <BlynkSimpleEsp8266.h>
//NEW AUTOCONNECT
#include <EEPROM.h>
//NEW AUTOCONNECT
char apiKey[32]="";
char apiKey2[32]="";
char channelKey2[16];
String channelKey21= "&";
char auth[] = "";
byte pinState = LOW;
// Your WiFi credentials.
// Set password to "" for open networks.
char ssid[] = "";
char pass[] = "";
 WiFiClient client;
//NEW AUTOCONNECT
int address = 0;
byte value;
      SPIFFS.format();
      ESP.reset();
      delay(1000);
int addr = 0;
void setup() {
pinMode(D5,OUTPUT);
digitalWrite(5,LOW);
//NEW AUTOCONNECT
 WiFiManagerParameter customAPIKey("apiKey", "Authorization Code", apiKey, 32);
wifiManager.autoConnect("FloWT2");
    if (!configFile) {
    delay(1000);
    configFile.close();
    //end save
  EEPROM.write(addr, 'D');    //Write character A
 String www =  apiKey2;
 Serial.println("thisiswww");
  Serial.print (www);
  EEPROM.commit();
WiFiClient client;
 EEPROM.begin(512);
  Serial.println(char(EEPROM.read(addr)));    //Read from address 0x04
  String uuu;
  for(int i=0;i<32;i++)
    uuu = uuu + char(EEPROM.read(0x0F+i)); //Read one by one with starting address of 0x0F
  Serial.print(uuu);  //Print the text on serial monitor
   uuu.toCharArray(auth,33);
Serial.println("auth");
Serial.print(auth);
   Blynk.begin(auth, ssid, pass);
void loop() {
Blynk.run();
AND THIS IS THE SCHEMATIC
Schematic
I forgot the 9K resistor on the green dotted line.
I am thinking of turning off the WiFi on Reset ESP before I turn on D5 pin but don't know if that will help.
Anyway thanks for everybody's help.
  • \$\begingroup\$ Would it be a good idea to change the Blynk ESP current to be more in line with the RF current. Since the RF current is around 1.6mA @ 3.3v after going through the voltage regulator would it make sense to make the Blynk ESP current 1.6mA @ 3.3v. This is what I was trying to do with the 9k resistor on the green dotted line. But I'm not sure what size resistor to use and should it go before or after the 1n4148 diode? Could someone help here. I am not an electrical engineer and need some advice. \$\endgroup\$ Apr 17, 2020 at 14:23
So by changing the code on the Reset ESP so that it disconnected from wifi before it turned on pin D5, everything now works great. Every time RF or Blynk ESP send a signal to relay it activates the set side and the Reset ESP runs and activates the Reset ESP 1st time every time. It is the code shown in the Reset ESP code above at the end.
