I've build the 555 timer and got my resistors and LEDs ready.
What I don't know or understand is how to shift a pattern using the serial in parallel out shift register (SN74LS164N).
I want to shift 10001100 using the shift register to shift LEDs (8 outputs). How can I do that? How can I make the connections or what are the connections? Or is there any other way without using this type of shift register?
Components that I've used: 555 timer capacitor resistors LEDS SIPO shift register SN74LS164N
is there anything else i need to add to the diagram? that will make the LEDs shift in the pattern
