Trying to have Fast PWM mode when TOP == ORCA.
Works fine with OCA toggle (measuring correct frequency), but doesn't work in non-inverting mode.
cli();
// Fast PWM Mode
TCCR2A = 0;
TCCR2A |= _BV(WGM20) | _BV(WGM21) | _BV(COM2A0) | _BV(COM2A1); // Inverting mode fails
//TCCR2A |= _BV(WGM20) | _BV(WGM21) | _BV(COM2A1); // Non-Inverting mode fails
//TCCR2A |= _BV(WGM20) | _BV(WGM21) | _BV(COM2A0); // Toggle mode OK
// Prescaler set to 1024 (p.162)
TCCR2B = 0;
TCCR2B |= _BV(CS20) | _BV(CS21) | _BV(CS22) | _BV(WGM22);
// Enable interrupt on counter match
TIMSK2 |= _BV(OCIE2A);
OCR2A = 127;
sei();
Update with more information:
MCU=Atmega328. In non-inverting mode I just got steady 1 on output and inverting mode gives logical 0. I was expecting to see the frequency
$$F = 16*10^6 / (1024 * 127) = 123Hz$$
  • \$\begingroup\$ What happens exactly when it "doesn't work"? What MCU is it? And what was the expected behavior as per you? The question needs a bit of clarity please. \$\endgroup\$ – Anindo Ghosh Nov 20 '12 at 23:06
  • \$\begingroup\$ Sorry, updated with clarifications. \$\endgroup\$ – Pablo Nov 20 '12 at 23:11
  • \$\begingroup\$ Worth to mention that Fast PWM (0xFF) mode works fine(WGM22=0). \$\endgroup\$ – Pablo Nov 20 '12 at 23:15
I will answer myself. OC2A pin is not generating frequency, because OCR2A is busy holding TOP value. It can hold either TOP value or output compare value. So I should use OCR2B.
To solve your controller problem, try this:
I just used the source code example of
http://www.electronicsplanet.ch/mikrocontroller/avrcodesammlung/atmega16timer0fastpwm.htm
and it worked. But thanks to your explanations, I understand why it works ;-)
