I'm currently studying for second order circuits, and I'm stuck understanding this example in my book pictured at the bottom.
- I got the same KCL equation, but I don't understand why the KVL equation on the right-hand mesh isn't $$v = \frac{1}{C}\int i(t)dt +6i+{L}\frac{di}{dt}$$ The book just has: $$v = 6i+{L}\frac{di}{dt}$$ and I don't understand why you don't account for the voltage across the capacitor. Even if it doesn't initially have voltage across it, it would still be changing, right? Because I think that we're concerned about the rate of change, not just the initial value or the infinity value.
- I am also a little confused why you cannot just take the derivative of the KCL equation like this: $$\frac{v}{4}+i_{L}+i_{C}= \frac{v_{s}}{4}$$ $$\frac{d}{dt}(\frac{v}{4}+\frac{1}{L}\int v(t)dt +C\frac{dv}{dt}=\frac{v_{s}}{4})$$
$$\frac{d^{2}v}{dt^{2}}+\frac{dv}{dt}+4 = \frac{dv_{s}}{dt}$$ which leads to the characteristic equation for the problem $$\lambda ^{2}+\lambda +4 =0$$
