I need to create a circuit that will have many cameras. Possibly the OVM7692. I will connect this array to my host processor via DVP.
The cameras are controlled via SCCB which seems to be a name that Omnivision gave to I2C. They will act as slave devices while the master (host processor) issue the commands (no problem here so far).
Now, to my question:
is it possible to interface a bus of DVP lines from all cameras (connect all outputs in parallel with each other) so I don't have to use one processor per camera? The idea is that only one camera will be used at a time. So control-wise: camera 1 to 6 are off and camera 7 takes a picture.
According to what I have seen on the image sensor datasheets, pins are in high-z while the device is set to low power mode.
However, I think adding some series resistances (22 to 51ohm) will be good in order to prevent an odd timing event and avoid a short.
Also, what about clock lines? will it be better to put some kind of buffer such as a NOT gate in between?
Thank you
