I am trying to order a PCIe golden finger. It is my first time to create this type of PCB. May I just double check that
  1. Gold tips should be on the top and bottom copper layers, right?
  2. I should do hard gold plating, right?
  3. Is it necessary to have beveling? I asked OSH PARK before since they dont provide beveling, they told me it doesn't matter. Since OSH PARK cannot do 4-layer work, I changed to Royal circuit, which can do beveling. I am not sure whether I should have it or not as Royal circuit also says that they can process standard ENIG with no bevel.
Thanks so much for your help!
  • \$\begingroup\$ There are some specs for PCIe devices that you should look at. An industry conglomerate called, "PCI-SIG" are basically the keepers of these specs. You should check their website as they have really everything you need to know on designing these devices. \$\endgroup\$
    – user103380
    Commented Apr 20, 2020 at 22:27
  • \$\begingroup\$ OSH PARK does do 4 layers, by the way, but not bevelling. \$\endgroup\$
    – DKNguyen
    Commented Apr 20, 2020 at 22:28
  • \$\begingroup\$ Thanks so much for your help! \$\endgroup\$
    – Ruiying Wu
    Commented Apr 21, 2020 at 15:22
Correct. Gold doesn't oxidize, so always presents a clean metallic surface for good electrical connection. The pins are also commonly accessible by end-users, whom like to touch them.
Should I do hard gold plating?
This depends on the application.
  • If a prototype board and you're anticipating limited insertions, standard tin plating is fine. The tin will wear away slightly with each cycle, eventually failing and possibly contaminating the connector. But you'll have spares, and anticipate this and be able to fix it easily.
  • If a final board and anticipating limited insertions, ENIG gold may be fine, such as OSH Park. The gold makes good electrical contact, but is slightly worn away each time. The gold layer is really thin, and ideally would only be inserted once.
  • If a final board and anticipating repeated insertions, "hard gold" plating is chosen. This is a thicker layer of gold and better process for depositing it. It still wears away, but since it's thicker, it will tolerate more insertions before failing.
This depends on the connector and application. Some connectors are designed to accept an un-beveled edge, while others may refuse to mate with it. I would suggest getting one of the connectors and trying the fit. You may find that sliding a fine diamond-file (at 45 degrees) once across both edges is enough to allow the connection to be made.
  • For prototyping use, it is understood that connectors might be a little more finicky than for a final design. The intended audience is also well-versed in electronics.
  • For a final design, the intended audience is the average consumer, with possibly zero understanding of connector mating principles and experience. So the easier and more reliably that connection is made (bevel), the better.
