I have this case where my V1 supply voltage is constant at 14V.
The C1 capacitor now charges up to 14V and assume my capacitor C1 is 35V rated.
But I have this condition where I need to check my circuit in case of high voltage say.
This is the pulse I need to apply.
My questions :
  1. V=E.(1-e^((-T)/(R.C))) - This is the formula I use to calculate the voltage at the capacitor after 50us. If I plug in my values of R (2ohms - should in the circuit which represents the resistance mentioned in the pulse specification), C(123.2uF - taken considering ALL tolerances),E and T, I get a value around 20.937V.
I have a query. My capacitor is rated properly if I measure this voltage after 50us. Suppose I measure like instantaneously, say after 10us, my capacitor fails. Should I not measure after 10us? If not, why should I not measure after 10us?
If I measure the voltage before that 50us, the voltage is going to be higher than the capacitor rated voltage. It won't fail? Or is it very small time for the capacitor to handle or accumulate?
  1. After 50us, my input V1 voltage goes back to 14V. But now my capacitor is holding 20.937V. What happens to this 20.937V? Assume I have connected a load across the capacitor. Does the excess voltage go to the load / source? If I have a reverse protection diode between the source and the capacitor, then where would this 20.937V go when the input voltage has come back to nominal 14V?
  • \$\begingroup\$ Your circuit shows 114 volts? \$\endgroup\$ – Andy aka Apr 21 at 9:00
  • \$\begingroup\$ Yes. During that 50us period, it will be total of 100+14=114V \$\endgroup\$ – Newbie Apr 21 at 9:20
  • \$\begingroup\$ Why not use a simulator? \$\endgroup\$ – Andy aka Apr 21 at 9:24
  • \$\begingroup\$ Unable to run the simulation. \$\endgroup\$ – Newbie Apr 21 at 9:56
    \$\begingroup\$ Not being able to run a simulation to me would be a bigger show-stopper than the problem you are trying to solve. \$\endgroup\$ – Andy aka Apr 21 at 10:06
Question #1 (will my capacitor fail sometime before 50 us): The formula you used to estimate your capacitor voltage after 50 us actually applies to a worse pulse than you have, which would be an instantaneous application of the full 114 Volts (a step). Your pulse is quite a bit less aggressive than this, so your estimate is high.
Even so, let's suppose you did just turn it on at full value instantaneously so that we are very conservative in our estimates. Immediately after turning on the full 114 Volts, your capacitor still only has the Uo=14V across it (assuming it had time to discharge to Uo between pulses). The extra 100 Volts you applied is all dropped across the resistor at first. The additional voltage across the capacitor ramps up in the manner described by your formula for V, except that the correct way to calculate it in your formula is to use E=100 Volts, and then add that to the Uo=14 Volts afterwards. So after 50 us of a step pulse, you would have 32.37 Volts across the capacitor. Your pulse is not that bad, though, and will have considerably less. For this step-pulse scenario, the pulse is ramping up monotonically from 14V to the 32.37 Volts, so it will actually be a lot less at 10 us than it would at 50 us (17.98 volts at 10 us). The upshot is that for this pulse train you describe, you will not come near 35 Volts across the capacitor.
Question #2 (what happens to the voltage on the capacitor between pulses: With no load attached, the charge on the capacitor flows back through the resistor into the source once the source voltage is less than the capacitor voltage. If you have a load, some will flow to the load (for simple resistive loads, anyway).
If you have a reverse-protection diode between the source and the capacitor, then no charge can flow back to the source (assume ideal diode here), and it can only go to the load. If there is no load, then the capacitor will just keep getting 'pumped' up from one pulse to the next until it approaches the full 114 Volts, and you will have made a simple peak detector. If you have a load, the load will drain some or all of this charge between pulses, depending upon the details of the load, and the voltage will be less than the full 114 Volts.
| improve this answer | |
  • \$\begingroup\$ Thank you for the answer. I understand that the pulse application is not instantaneous. It gradually rises. But how would I compute without this formula? Could you help me with how would your computation method for this? And please also help on how to calculate the maximum power of a single pulse. I understand to get the power, we need to integrate the area under the curve. But how to do that calculation. \$\endgroup\$ – Newbie Apr 25 at 15:08
    \$\begingroup\$ @Newbie My advice is not to try to compute the capacitor voltage with the pulse you have, but first do the worst-case scenario, which is V1 steps instantaneously to 100 Volts. Then you can use the formula you used, except with E=100 Volts to find out how much voltage you are adding to the cap as a function of time ,beyond the Uo=14V. If you do this, you find that in the first 50 us, the cap stays below 35 Volts the whole time from 0 to 50 us. So then you are done! Your cap is safe, and you don't need more precision. You can stop at 50 us because your actual V1 pulse has come below 35V. \$\endgroup\$ – rpm2718 Apr 25 at 15:22
  • \$\begingroup\$ Thank you for the suggestion. \$\endgroup\$ – Newbie Apr 25 at 15:25
Suppose, I measure like instantaneously, say after 10us, my capacitor fails. Should I not measure after 10us ? If not, why should I not measure after 10us ?
Measuring the voltage has nothing to do with failure of the capacitor.
No one can say for certain whether a given capacitor will fail or not under a brief overvoltage situation. If you exceed the manufacturer's specifications then the probability of failure goes up and, more importantly, you have no recourse with the manufacturer if the capacitor does fail.
If you connect a load across the capacitor then the voltage across the capacitor and the load will always be exactly the same. If you put a reverse-biased diode between the source and the capacitor then the capacitor would slowly discharge to the source voltage due to the diode leakage current.
  • \$\begingroup\$ In you last portion of the answer, when will the voltage of the capacitor return from 20.937V to 14V? How will it return to the nominal voltage from 20.937V to 14V \$\endgroup\$ – Newbie Apr 23 at 14:15
    \$\begingroup\$ The capacitor returns to the source voltage because the diode current is not exactly zero in reverse bias. The time required to return to 14V is determined by the reverse-bias diode leakage, which you have not specified. \$\endgroup\$ – Elliot Alderson Apr 23 at 14:44
MLCC manufacturers won't spec a capacitor to absorb this pulse. Some will have tested to this level, but it won't be in the spec. To properly protect downstream components from pulse 2a you would want to use a voltage suppressor - varistor, TVS diode, or an ESD rated capacitor to absorb the voltage.
