I would really appreciate if someone would share his insights on whether an isolated DC/DC converter of a fixed output (12V) can sustain that output even when input is lower than 12V, the datasheet says the input range 9-36 VDC which may be the answer but i would really like to get a confirmation if possible.
Also a side question, this datasheet does not indicate any input or output filters or recommended capacitors for optimal operation except a 10F MLCC at the output , any recommendations on this ? my thought was to throw a few bulk capacitors at the input/output and call it a day.
DC/DC Converter
Datasheet
First of all read this section in the data sheet on how to make it compliant with EN55032: -
Secondy, yes it will work from 9 volts input to 36 volts input because, internally, is a flyback converter.
