I purchased SN74LS26N quadruple 2-input NAND Gates chips for my circuit. Before I insert any chip into circuit I test it on separate breadboard.
So I did with this chip and I get NO output when my inputs are LOW...
Does it make any sense to you? I am doing something wrong?
I am not the best with schematics so I hope this is clean for you.. I tried adding bypass electrolytic caps 0.1uF but that didn't help
Thanks!
are connected to GND @Transistor - this is normally connected to GND on breadboard... as I said I'm not the best with schematics so it may looks wrong there... sorry @ElliotAlderson - I measured the voltage... 0.1V-0.3V @Andyaka - No, they are not "glowing" slightly. on the same set up SN74LS00N chip is working perfect. Pinout is the same so I am not sure what's wrong... [Data sheet ](ti.com/lit/ds/symlink/sn74ls26.pdf) says it'sHigh voltage Positive NAND-Gate
. Does it make a difference? \$\endgroup\$
