Hil all, how are you?. I'm trying to simulate the IR2110 in proteus ISIS (is not modelled nativelly), then I've downloaded the model from infineon and followed the tutorial from labcenter to make de device, after make the device then I tried to simulate the new device but I'm having an error in PROSPICE which says "Too few parameters for subcircuit type "IR2110" (instance: xU2)" where the code of the model is the following:
* * Copyright (c) International Rectifier * * IR2110: High and Low Side Driver *
* Ports * VDD: Logic Supply * HIN: Logic Input for High Side Gate Driver Output (HO), in phase * SD: Logic Input for Shutdown * LIN: Logic Input for Low Side Gate Driver Output (LO), in phase * VSS: Logic Ground * VB: High Side Floating Supply * HO: High Side Gate Diver Output * VS: High Side Floating Supply Return * VC: Low Side Supply * LO: Low Side Gate Driver Output * COM: Low Side Return * * Created by Pspice Version 8 * * Date Created: 03/25/2003 *
* * This behavioral model was developed in compliance with Data Sheet * No. PD60147-R except noted below: * (1) There is no frequency effect on temperature. * (2) The power dissipation is different. * (3) The values of output high/low short circuit current are adjusted * for the proper modeling of turn-on rise/turn-off fall time. * (4) The "Low side return (COM)" pin must be grounded.
.SUBCKT IR2110 VDD HIN SD LIN VSS HO VB VS VC COM LO +PARAMS:
+ T1=-40 T2=25 T3=125 + V1=10 V2=15 V3=20 + tonT1=90n tonT2=120n tonT3=170n + tonV1=140n tonV2=120n tonV3=100n + toffT1=77n toffT2=94n toffT3=130n + toffV1=115n toffV2=94n toffV3=75n + tonVdd1=125n tonVdd2=120n tonVdd3=115n + toffVdd1=113n toffVdd2=94n toffVdd3=72n
.MODEL diode25 d +IS=1.0e-14 RS=0.01 N=1 EG=1.11 +XTI=3 BV=25 IBV=0.0001 CJO=0 +VJ=0.75 M=0.333 FC=0.5 TT=0 +KF=0 AF=1
.MODEL diode525 d +IS=1.0e-14 RS=0.01 N=1 EG=1.11 +XTI=3 BV=525 IBV=0.0001 CJO=0 +VJ=0.75 M=0.333 FC=0.5 TT=0 +KF=0 AF=1
C_MD1_C2 VSS MD2_Nor3b_2 10p
C_MD1_C3 VSS MD2_Inv2_1 10p
C_MD1_C1 VSS MD2_Inv1_1 1n
D_MD1_D2 VSS HIN diode25 D_MD1_D3 SD VDD diode25 D_MD1_D4 VSS SD diode25 D_MD1_D5 LIN VDD diode25 D_MD1_D6 VSS LIN diode25 D_MD1_D7 VSS VDD diode25 D_MD1_D1 HIN VDD diode25 C_MD1_Trig3_CTrig VSS MD2_Inv2_1 10p
R_MD1_Trig3_R1Trig MD1_Trig3_3 VDD 100Meg
R_MD1_Trig3_R2Trig MD1_Trig3_4 MD1_Trig3_3 66.7Meg
R_MD1_Trig3_R3Trig VSS MD1_Trig3_4 106.1Meg
X_MD1_Trig3_Comp LIN MD1_Trig3_3 MD2_Inv2_1 com COMP S_MD1_Trig3_PTrig MD1_Trig3_4 VSS MD2_Inv2_1 VSS _MD1_Trig3_PTrig RS_MD1_Trig3_PTrig MD2_Inv2_1 VSS 1G .MODEL _MD1_Trig3_PTrig VSWITCH Roff=1e9 Ron=1 Voff=0.01 Von=4.99 R_MD1_R1 VSS HIN 750k TC=-0.00783811, 0.0000372046 R_MD1_R2 VSS SD 750k TC=-0.00783811, 0.0000372046 C_MD1_Trig1_CTrig VSS MD2_Inv1_1 10p
R_MD1_Trig1_R1Trig MD1_Trig1_3 VDD 100Meg
R_MD1_Trig1_R2Trig MD1_Trig1_4 MD1_Trig1_3 66.7Meg
R_MD1_Trig1_R3Trig VSS MD1_Trig1_4 106.1Meg
X_MD1_Trig1_Comp HIN MD1_Trig1_3 MD2_Inv1_1 com COMP S_MD1_Trig1_PTrig MD1_Trig1_4 VSS MD2_Inv1_1 VSS _MD1_Trig1_PTrig RS_MD1_Trig1_PTrig MD2_Inv1_1 VSS 1G .MODEL _MD1_Trig1_PTrig VSWITCH Roff=1e9 Ron=1 Voff=0.01 Von=4.99 C_MD1_Trig2_CTrig VSS MD2_Nor3b_2 10p
R_MD1_Trig2_R1Trig MD1_Trig2_3 VDD 100Meg
R_MD1_Trig2_R2Trig MD1_Trig2_4 MD1_Trig2_3 66.7Meg
R_MD1_Trig2_R3Trig VSS MD1_Trig2_4 106.1Meg
X_MD1_Trig2_Comp SD MD1_Trig2_3 MD2_Nor3b_2 com COMP S_MD1_Trig2_PTrig MD1_Trig2_4 VSS MD2_Nor3b_2 VSS _MD1_Trig2_PTrig RS_MD1_Trig2_PTrig MD2_Nor3b_2 VSS 1G .MODEL _MD1_Trig2_PTrig VSWITCH Roff=1e9 Ron=1 Voff=0.01 Von=4.99 R_MD1_R3 VSS LIN 750k TC=-0.00783811, 0.0000372046 R_MD1_R4 VSS VDD 7.5Meg TC=-0.00505291, 0.0000236999 C_MD2_C1 VSS MD3_DlyHS_2 10p IC=0 C_MD2_C2 VSS MD3_DlyLS_2 10p IC=0 V_MD2_Inv1_V MD2_Inv1_2 VSS 5V C_MD2_Inv1_C VSS MD2_Nor3a_3 1p
S_MD2_Inv1_P MD2_Inv1_2 MD2_Nor3a_3 MD2_Inv1_1 VSS _MD2_Inv1_P RS_MD2_Inv1_P MD2_Inv1_1 VSS 1G .MODEL _MD2_Inv1_P VSWITCH Roff=1e6 Ron=1 Voff=4.9V Von=0.1V S_MD2_Inv1_N MD2_Nor3a_3 VSS MD2_Inv1_1 VSS _MD2_Inv1_N RS_MD2_Inv1_N MD2_Inv1_1 VSS 1G .MODEL _MD2_Inv1_N VSWITCH Roff=1e6 Ron=1 Voff=0.1V Von=4.9V V_MD2_Inv2_V MD2_Inv2_2 VSS 5V C_MD2_Inv2_C VSS MD2_Nor3b_1 1p
S_MD2_Inv2_P MD2_Inv2_2 MD2_Nor3b_1 MD2_Inv2_1 VSS _MD2_Inv2_P RS_MD2_Inv2_P MD2_Inv2_1 VSS 1G .MODEL _MD2_Inv2_P VSWITCH Roff=1e6 Ron=1 Voff=4.9V Von=0.1V S_MD2_Inv2_N MD2_Nor3b_1 VSS MD2_Inv2_1 VSS _MD2_Inv2_N RS_MD2_Inv2_N MD2_Inv2_1 VSS 1G .MODEL _MD2_Inv2_N VSWITCH Roff=1e6 Ron=1 Voff=0.1V Von=4.9V C_MD2_RS1_C7 MD2_RS1_6 MD2_RS1_5 10p
C_MD2_RS1_C2 VSS MD2_Nor3a_3 10p IC=0 C_MD2_RS1_C3 VSS MD2_Nor3b_2 10p IC=0 C_MD2_RS1_C10 MD2_RS1_7 MD2_RS1_5 10p
C_MD2_RS1_C11 MD2_RS1_3 MD2_RS1_7 10p
C_MD2_RS1_C12 VSS MD2_RS1_3 10p
C_MD2_RS1_C9 VSS MD2_Nor3a_1 10p
C_MD2_RS1_C8 MD2_Nor3a_1 MD2_RS1_6 10p
C_MD2_RS1_C1 VSS MD2_Nor3a_1 10p IC=0 S_MD2_RS1_P1 MD2_RS1_5 MD2_RS1_6 MD2_Nor3a_3 VSS _MD2_RS1_P1 RS_MD2_RS1_P1 MD2_Nor3a_3 VSS 1G .MODEL _MD2_RS1_P1 VSWITCH Roff=1e6 Ron=1m Voff=4.9V Von=0.1V S_MD2_RS1_P2 MD2_RS1_6 MD2_Nor3a_1 MD2_RS1_3 VSS _MD2_RS1_P2 RS_MD2_RS1_P2 MD2_RS1_3 VSS 1G .MODEL _MD2_RS1_P2 VSWITCH Roff=1e6 Ron=1m Voff=4.9V Von=0.1V S_MD2_RS1_N1 MD2_Nor3a_1 VSS MD2_RS1_3 VSS _MD2_RS1_N1 RS_MD2_RS1_N1 MD2_RS1_3 VSS 1G .MODEL _MD2_RS1_N1 VSWITCH Roff=1e8 Ron=1m Voff=0.1V Von=4.9V S_MD2_RS1_P3 MD2_RS1_5 MD2_RS1_7 MD2_Nor3b_2 VSS _MD2_RS1_P3 RS_MD2_RS1_P3 MD2_Nor3b_2 VSS 1G .MODEL _MD2_RS1_P3 VSWITCH Roff=1e6 Ron=1m Voff=4.9V Von=0.1V S_MD2_RS1_P4 MD2_RS1_7 MD2_RS1_3 MD2_Nor3a_1 VSS _MD2_RS1_P4 RS_MD2_RS1_P4 MD2_Nor3a_1 VSS 1G .MODEL _MD2_RS1_P4 VSWITCH Roff=1e6 Ron=1m Voff=4.9V Von=0.1V S_MD2_RS1_N3 MD2_RS1_3 VSS MD2_Nor3b_2 VSS _MD2_RS1_N3 RS_MD2_RS1_N3 MD2_Nor3b_2 VSS 1G .MODEL _MD2_RS1_N3 VSWITCH Roff=1e8 Ron=1m Voff=0.1V Von=4.9V V_MD2_RS1_V1 MD2_RS1_5 VSS 5V S_MD2_RS1_N4 MD2_RS1_3 VSS MD2_Nor3a_1 VSS _MD2_RS1_N4 RS_MD2_RS1_N4 MD2_Nor3a_1 VSS 1G .MODEL _MD2_RS1_N4 VSWITCH Roff=1e8 Ron=1m Voff=0.1V Von=4.9V S_MD2_RS1_N2 MD2_Nor3a_1 VSS MD2_Nor3a_3 VSS _MD2_RS1_N2 RS_MD2_RS1_N2 MD2_Nor3a_3 VSS 1G .MODEL _MD2_RS1_N2 VSWITCH Roff=1e8 Ron=1m Voff=0.1V Von=4.9V C_MD2_RS2_C7 MD2_RS2_6 MD2_RS2_5 10p
C_MD2_RS2_C2 VSS MD2_Nor3b_1 10p IC=0 C_MD2_RS2_C3 VSS MD2_Nor3b_2 10p IC=0 C_MD2_RS2_C10 MD2_RS2_7 MD2_RS2_5 10p
C_MD2_RS2_C11 MD2_RS2_3 MD2_RS2_7 10p
C_MD2_RS2_C12 VSS MD2_RS2_3 10p
C_MD2_RS2_C9 VSS MD2_Nor3b_3 10p
C_MD2_RS2_C8 MD2_Nor3b_3 MD2_RS2_6 10p
C_MD2_RS2_C1 VSS MD2_Nor3b_3 10p IC=0 S_MD2_RS2_P1 MD2_RS2_5 MD2_RS2_6 MD2_Nor3b_1 VSS _MD2_RS2_P1 RS_MD2_RS2_P1 MD2_Nor3b_1 VSS 1G .MODEL _MD2_RS2_P1 VSWITCH Roff=1e6 Ron=1m Voff=4.9V Von=0.1V S_MD2_RS2_P2 MD2_RS2_6 MD2_Nor3b_3 MD2_RS2_3 VSS _MD2_RS2_P2 RS_MD2_RS2_P2 MD2_RS2_3 VSS 1G .MODEL _MD2_RS2_P2 VSWITCH Roff=1e6 Ron=1m Voff=4.9V Von=0.1V S_MD2_RS2_N1 MD2_Nor3b_3 VSS MD2_RS2_3 VSS _MD2_RS2_N1 RS_MD2_RS2_N1 MD2_RS2_3 VSS 1G .MODEL _MD2_RS2_N1 VSWITCH Roff=1e8 Ron=1m Voff=0.1V Von=4.9V S_MD2_RS2_P3 MD2_RS2_5 MD2_RS2_7 MD2_Nor3b_2 VSS _MD2_RS2_P3 RS_MD2_RS2_P3 MD2_Nor3b_2 VSS 1G .MODEL _MD2_RS2_P3 VSWITCH Roff=1e6 Ron=1m Voff=4.9V Von=0.1V S_MD2_RS2_P4 MD2_RS2_7 MD2_RS2_3 MD2_Nor3b_3 VSS _MD2_RS2_P4 RS_MD2_RS2_P4 MD2_Nor3b_3 VSS 1G .MODEL _MD2_RS2_P4 VSWITCH Roff=1e6 Ron=1m Voff=4.9V Von=0.1V S_MD2_RS2_N3 MD2_RS2_3 VSS MD2_Nor3b_2 VSS _MD2_RS2_N3 RS_MD2_RS2_N3 MD2_Nor3b_2 VSS 1G .MODEL _MD2_RS2_N3 VSWITCH Roff=1e8 Ron=1m Voff=0.1V Von=4.9V V_MD2_RS2_V1 MD2_RS2_5 VSS 5V S_MD2_RS2_N4 MD2_RS2_3 VSS MD2_Nor3b_3 VSS _MD2_RS2_N4 RS_MD2_RS2_N4 MD2_Nor3b_3 VSS 1G .MODEL _MD2_RS2_N4 VSWITCH Roff=1e8 Ron=1m Voff=0.1V Von=4.9V S_MD2_RS2_N2 MD2_Nor3b_3 VSS MD2_Nor3b_1 VSS _MD2_RS2_N2 RS_MD2_RS2_N2 MD2_Nor3b_1 VSS 1G .MODEL _MD2_RS2_N2 VSWITCH Roff=1e8 Ron=1m Voff=0.1V Von=4.9V S_MD2_Nor3a_P1 MD2_Nor3a_4 MD2_Nor3a_5 MD2_Nor3a_1 VSS _MD2_Nor3a_P1 RS_MD2_Nor3a_P1 MD2_Nor3a_1 VSS 1G .MODEL _MD2_Nor3a_P1 VSWITCH Roff=1e6 Ron=1 Voff=4.9V Von=0.1V S_MD2_Nor3a_P2 MD2_Nor3a_5 MD2_Nor3a_6 MD2_Nor3b_2 VSS _MD2_Nor3a_P2 RS_MD2_Nor3a_P2 MD2_Nor3b_2 VSS 1G .MODEL _MD2_Nor3a_P2 VSWITCH Roff=1e6 Ron=1 Voff=4.9V Von=0.1V S_MD2_Nor3a_P3 MD2_Nor3a_6 MD3_DlyHS_2 MD2_Nor3a_3 VSS _MD2_Nor3a_P3 RS_MD2_Nor3a_P3 MD2_Nor3a_3 VSS 1G .MODEL _MD2_Nor3a_P3 VSWITCH Roff=1e6 Ron=1 Voff=4.9V Von=0.1V S_MD2_Nor3a_N1 MD3_DlyHS_2 VSS MD2_Nor3b_2 VSS _MD2_Nor3a_N1 RS_MD2_Nor3a_N1 MD2_Nor3b_2 VSS 1G .MODEL _MD2_Nor3a_N1 VSWITCH Roff=1e6 Ron=1 Voff=0.1V Von=4.9V V_MD2_Nor3a_V MD2_Nor3a_4 VSS 5V S_MD2_Nor3a_N2 MD3_DlyHS_2 VSS MD2_Nor3a_1 VSS _MD2_Nor3a_N2 RS_MD2_Nor3a_N2 MD2_Nor3a_1 VSS 1G .MODEL _MD2_Nor3a_N2 VSWITCH Roff=1e6 Ron=1 Voff=0.1V Von=4.9V S_MD2_Nor3a_N3 MD3_DlyHS_2 VSS MD2_Nor3a_3 VSS _MD2_Nor3a_N3 RS_MD2_Nor3a_N3 MD2_Nor3a_3 VSS 1G .MODEL _MD2_Nor3a_N3 VSWITCH Roff=1e6 Ron=1 Voff=0.1V Von=4.9V S_MD2_Nor3b_P1 MD2_Nor3b_4 MD2_Nor3b_5 MD2_Nor3b_1 VSS _MD2_Nor3b_P1 RS_MD2_Nor3b_P1 MD2_Nor3b_1 VSS 1G .MODEL _MD2_Nor3b_P1 VSWITCH Roff=1e6 Ron=1 Voff=4.9V Von=0.1V S_MD2_Nor3b_P2 MD2_Nor3b_5 MD2_Nor3b_6 MD2_Nor3b_2 VSS _MD2_Nor3b_P2 RS_MD2_Nor3b_P2 MD2_Nor3b_2 VSS 1G .MODEL _MD2_Nor3b_P2 VSWITCH Roff=1e6 Ron=1 Voff=4.9V Von=0.1V S_MD2_Nor3b_P3 MD2_Nor3b_6 MD3_DlyLS_2 MD2_Nor3b_3 VSS _MD2_Nor3b_P3 RS_MD2_Nor3b_P3 MD2_Nor3b_3 VSS 1G .MODEL _MD2_Nor3b_P3 VSWITCH Roff=1e6 Ron=1 Voff=4.9V Von=0.1V S_MD2_Nor3b_N1 MD3_DlyLS_2 VSS MD2_Nor3b_2 VSS _MD2_Nor3b_N1 RS_MD2_Nor3b_N1 MD2_Nor3b_2 VSS 1G .MODEL _MD2_Nor3b_N1 VSWITCH Roff=1e6 Ron=1 Voff=0.1V Von=4.9V V_MD2_Nor3b_V MD2_Nor3b_4 VSS 5V S_MD2_Nor3b_N2 MD3_DlyLS_2 VSS MD2_Nor3b_1 VSS _MD2_Nor3b_N2 RS_MD2_Nor3b_N2 MD2_Nor3b_1 VSS 1G .MODEL _MD2_Nor3b_N2 VSWITCH Roff=1e6 Ron=1 Voff=0.1V Von=4.9V S_MD2_Nor3b_N3 MD3_DlyLS_2 VSS MD2_Nor3b_3 VSS _MD2_Nor3b_N3 RS_MD2_Nor3b_N3 MD2_Nor3b_3 VSS 1G .MODEL _MD2_Nor3b_N3 VSWITCH Roff=1e6 Ron=1 Voff=0.1V Von=4.9V D_MD5_D2 com LO diode25 D_MD5_D1 LO VC diode25 C_MD5_C com LO 10p
C_MD5_UVC_c1 MD5_UVC_2 MD5_UVC_3 10n
C_MD5_UVC_c2 MD5_UVC_4 MD5_UVC_2 10n
C_MD5_UVC_c3 com MD4_Inv5_1 10p
E_MD5_UVC_ABM2 MD5_UVC_3 com VALUE { 8.3+(8.8-8.3)/(125+40)(TEMP+40)
+ } E_MD5_UVC_ABM3 MD5_UVC_4 com VALUE { 8.0+(8.5-8.0)/(125+40)
(TEMP+40)
+ } X_MD5_UVC_Comp VC MD5_UVC_2 MD4_Inv5_1 com COMP S_MD5_UVC_P MD5_UVC_3 MD5_UVC_2 MD4_Inv5_1 com _MD5_UVC_P RS_MD5_UVC_P MD4_Inv5_1 com 1G .MODEL _MD5_UVC_P VSWITCH Roff=1e6 Ron=1 Voff=4.99 Von=0.01 S_MD5_UVC_N MD5_UVC_2 MD5_UVC_4 MD4_Inv5_1 com _MD5_UVC_N RS_MD5_UVC_N MD4_Inv5_1 com 1G .MODEL _MD5_UVC_N VSWITCH Roff=1e6 Ron=1 Voff=0.01 Von=4.99 S_MD5_Nand_P1 MD5_Nand_5 MD5_OLS_1 MD4_Inv5_1 VSS _MD5_Nand_P1 RS_MD5_Nand_P1 MD4_Inv5_1 VSS 1G .MODEL _MD5_Nand_P1 VSWITCH Roff=1e6 Ron=1 Voff=4.9 Von=0.1 S_MD5_Nand_N1 MD5_OLS_1 MD5_Nand_4 MD3_DlyLS_8 VSS _MD5_Nand_N1 RS_MD5_Nand_N1 MD3_DlyLS_8 VSS 1G .MODEL _MD5_Nand_N1 VSWITCH Roff=1e6 Ron=1 Voff=0.1 Von=4.9 S_MD5_Nand_P2 MD5_Nand_5 MD5_OLS_1 MD3_DlyLS_8 VSS _MD5_Nand_P2 RS_MD5_Nand_P2 MD3_DlyLS_8 VSS 1G .MODEL _MD5_Nand_P2 VSWITCH Roff=1e6 Ron=1 Voff=4.9 Von=0.1 V_MD5_Nand_V MD5_Nand_5 VSS 5V S_MD5_Nand_N2 MD5_Nand_4 VSS MD4_Inv5_1 VSS _MD5_Nand_N2 RS_MD5_Nand_N2 MD4_Inv5_1 VSS 1G .MODEL _MD5_Nand_N2 VSWITCH Roff=1e6 Ron=1 Voff=0.1 Von=4.9 S_MD5_OLS_P VC MD5_OLS_2 MD5_OLS_1 com _MD5_OLS_P RS_MD5_OLS_P MD5_OLS_1 com 1G .MODEL _MD5_OLS_P VSWITCH Roff=1e9 Ron=1m Voff=4.9 Von=0.1 S_MD5_OLS_N MD5_OLS_3 com MD5_OLS_1 com _MD5_OLS_N RS_MD5_OLS_N MD5_OLS_1 com 1G .MODEL _MD5_OLS_N VSWITCH Roff=1e9 Ron=1m Voff=0.1 Von=4.9 R_MD5_OLS_R6 LO MD5_OLS_2 11.4 TC=0.00190676, 9.3240e-07 R_MD5_OLS_R7 MD5_OLS_3 LO 7.76 TC=0.00241396, 2.331e-06 R_MD5_R com VC 83.3k TC=-0.00358599, 0.0000124556 D_MD5_D3 com VC diode25 D_MD4_D2 HO VB diode25 D_MD4_D1 VS VB diode25 D_MD4_D4 com VB diode525 D_MD4_D5 com VS diode525 D_MD4_D3 VS HO diode25 C_MD4_C3 VS HO 10p IC=0 C_MD4_Uvbs_c1 MD4_Uvbs_2 MD4_Uvbs_4 10n
C_MD4_Uvbs_c2 MD4_Uvbs_5 MD4_Uvbs_2 10n
C_MD4_Uvbs_c3 com MD4_Inv4_1 10p
E_MD4_Uvbs_ABM18 MD4_Uvbs_4 com VALUE { + V(VS)+8.4+(8.9-8.4)/(125+40)(TEMP+40) } E_MD4_Uvbs_ABM19 MD4_Uvbs_5 com VALUE { + V(VS)+8.0+(8.45-8.0)/(125+40)(TEMP+40) } X_MD4_Uvbs_Comp VB MD4_Uvbs_2 MD4_Inv4_1 com COMP S_MD4_Uvbs_P MD4_Uvbs_4 MD4_Uvbs_2 MD4_Inv4_1 com _MD4_Uvbs_P RS_MD4_Uvbs_P MD4_Inv4_1 com 1G .MODEL _MD4_Uvbs_P VSWITCH Roff=1e6 Ron=1 Voff=4.99 Von=0.01 S_MD4_Uvbs_N MD4_Uvbs_2 MD4_Uvbs_5 MD4_Inv4_1 com _MD4_Uvbs_N RS_MD4_Uvbs_N MD4_Inv4_1 com 1G .MODEL _MD4_Uvbs_N VSWITCH Roff=1e6 Ron=1 Voff=0.01 Von=4.99 V_MD4_Inv3_V MD4_Inv3_2 VSS 5V C_MD4_Inv3_C VSS MD4_OHS_1 1p
S_MD4_Inv3_P MD4_Inv3_2 MD4_OHS_1 MD4_RS_4 VSS _MD4_Inv3_P RS_MD4_Inv3_P MD4_RS_4 VSS 1G .MODEL _MD4_Inv3_P VSWITCH Roff=1e6 Ron=1 Voff=4.9V Von=0.1V S_MD4_Inv3_N MD4_OHS_1 VSS MD4_RS_4 VSS _MD4_Inv3_N RS_MD4_Inv3_N MD4_RS_4 VSS 1G .MODEL _MD4_Inv3_N VSWITCH Roff=1e6 Ron=1 Voff=0.1V Von=4.9V C_MD4_RS_C7 MD4_RS_6 MD4_RS_5 10p
C_MD4_RS_C2 VSS MD4_Inv2_3 10p IC=0 C_MD4_RS_C3 VSS MD3_DlyHS_8 10p IC=0 C_MD4_RS_C10 MD4_RS_7 MD4_RS_5 10p
C_MD4_RS_C11 MD4_RS_3 MD4_RS_7 10p
C_MD4_RS_C12 VSS MD4_RS_3 10p
C_MD4_RS_C9 VSS MD4_RS_4 10p
C_MD4_RS_C8 MD4_RS_4 MD4_RS_6 10p
C_MD4_RS_C1 VSS MD4_RS_4 10p IC=0 S_MD4_RS_P1 MD4_RS_5 MD4_RS_6 MD4_Inv2_3 VSS _MD4_RS_P1 RS_MD4_RS_P1 MD4_Inv2_3 VSS 1G .MODEL _MD4_RS_P1 VSWITCH Roff=1e6 Ron=1m Voff=4.9V Von=0.1V S_MD4_RS_P2 MD4_RS_6 MD4_RS_4 MD4_RS_3 VSS _MD4_RS_P2 RS_MD4_RS_P2 MD4_RS_3 VSS 1G .MODEL _MD4_RS_P2 VSWITCH Roff=1e6 Ron=1m Voff=4.9V Von=0.1V S_MD4_RS_N1 MD4_RS_4 VSS MD4_RS_3 VSS _MD4_RS_N1 RS_MD4_RS_N1 MD4_RS_3 VSS 1G .MODEL _MD4_RS_N1 VSWITCH Roff=1e8 Ron=1m Voff=0.1V Von=4.9V S_MD4_RS_P3 MD4_RS_5 MD4_RS_7 MD3_DlyHS_8 VSS _MD4_RS_P3 RS_MD4_RS_P3 MD3_DlyHS_8 VSS 1G .MODEL _MD4_RS_P3 VSWITCH Roff=1e6 Ron=1m Voff=4.9V Von=0.1V S_MD4_RS_P4 MD4_RS_7 MD4_RS_3 MD4_RS_4 VSS _MD4_RS_P4 RS_MD4_RS_P4 MD4_RS_4 VSS 1G .MODEL _MD4_RS_P4 VSWITCH Roff=1e6 Ron=1m Voff=4.9V Von=0.1V S_MD4_RS_N3 MD4_RS_3 VSS MD3_DlyHS_8 VSS _MD4_RS_N3 RS_MD4_RS_N3 MD3_DlyHS_8 VSS 1G .MODEL _MD4_RS_N3 VSWITCH Roff=1e8 Ron=1m Voff=0.1V Von=4.9V V_MD4_RS_V1 MD4_RS_5 VSS 5V S_MD4_RS_N4 MD4_RS_3 VSS MD4_RS_4 VSS _MD4_RS_N4 RS_MD4_RS_N4 MD4_RS_4 VSS 1G .MODEL _MD4_RS_N4 VSWITCH Roff=1e8 Ron=1m Voff=0.1V Von=4.9V S_MD4_RS_N2 MD4_RS_4 VSS MD4_Inv2_3 VSS _MD4_RS_N2 RS_MD4_RS_N2 MD4_Inv2_3 VSS 1G .MODEL _MD4_RS_N2 VSWITCH Roff=1e8 Ron=1m Voff=0.1V Von=4.9V V_MD4_Inv2_V MD4_Inv2_2 VSS 5V C_MD4_Inv2_C VSS MD4_Inv2_3 1p
S_MD4_Inv2_P MD4_Inv2_2 MD4_Inv2_3 MD4_Nor1_5 VSS _MD4_Inv2_P RS_MD4_Inv2_P MD4_Nor1_5 VSS 1G .MODEL _MD4_Inv2_P VSWITCH Roff=1e6 Ron=1 Voff=4.9V Von=0.1V S_MD4_Inv2_N MD4_Inv2_3 VSS MD4_Nor1_5 VSS _MD4_Inv2_N RS_MD4_Inv2_N MD4_Nor1_5 VSS 1G .MODEL _MD4_Inv2_N VSWITCH Roff=1e6 Ron=1 Voff=0.1V Von=4.9V V_MD4_Inv1_V MD4_Inv1_2 VSS 5V C_MD4_Inv1_C VSS MD4_Nor1_1 1p
S_MD4_Inv1_P MD4_Inv1_2 MD4_Nor1_1 MD3_DlyHS_8 VSS _MD4_Inv1_P RS_MD4_Inv1_P MD3_DlyHS_8 VSS 1G .MODEL _MD4_Inv1_P VSWITCH Roff=1e6 Ron=1 Voff=4.9V Von=0.1V S_MD4_Inv1_N MD4_Nor1_1 VSS MD3_DlyHS_8 VSS _MD4_Inv1_N RS_MD4_Inv1_N MD3_DlyHS_8 VSS 1G .MODEL _MD4_Inv1_N VSWITCH Roff=1e6 Ron=1 Voff=0.1V Von=4.9V V_MD4_Inv4_V MD4_Inv4_2 VSS 5V C_MD4_Inv4_C VSS MD4_Nor2_2 1p
S_MD4_Inv4_P MD4_Inv4_2 MD4_Nor2_2 MD4_Inv4_1 VSS _MD4_Inv4_P RS_MD4_Inv4_P MD4_Inv4_1 VSS 1G .MODEL _MD4_Inv4_P VSWITCH Roff=1e6 Ron=1 Voff=4.9V Von=0.1V S_MD4_Inv4_N MD4_Nor2_2 VSS MD4_Inv4_1 VSS _MD4_Inv4_N RS_MD4_Inv4_N MD4_Inv4_1 VSS 1G .MODEL _MD4_Inv4_N VSWITCH Roff=1e6 Ron=1 Voff=0.1V Von=4.9V V_MD4_Nor1_V MD4_Nor1_3 VSS 5V S_MD4_Nor1_P1 MD4_Nor1_3 MD4_Nor1_4 MD4_Nor1_1 VSS _MD4_Nor1_P1 RS_MD4_Nor1_P1 MD4_Nor1_1 VSS 1G .MODEL _MD4_Nor1_P1 VSWITCH Roff=1e6 Ron=1 Voff=4.9 Von=0.1 S_MD4_Nor1_P2 MD4_Nor1_4 MD4_Nor1_5 MD4_Inv6_3 VSS _MD4_Nor1_P2 RS_MD4_Nor1_P2 MD4_Inv6_3 VSS 1G .MODEL _MD4_Nor1_P2 VSWITCH Roff=1e6 Ron=1 Voff=4.9 Von=0.1 S_MD4_Nor1_N1 MD4_Nor1_5 VSS MD4_Inv6_3 VSS _MD4_Nor1_N1 RS_MD4_Nor1_N1 MD4_Inv6_3 VSS 1G .MODEL _MD4_Nor1_N1 VSWITCH Roff=1e6 Ron=1 Voff=0.1 Von=4.9 S_MD4_Nor1_N2 MD4_Nor1_5 VSS MD4_Nor1_1 VSS _MD4_Nor1_N2 RS_MD4_Nor1_N2 MD4_Nor1_1 VSS 1G .MODEL _MD4_Nor1_N2 VSWITCH Roff=1e6 Ron=1 Voff=0.1 Von=4.9 V_MD4_Inv5_V MD4_Inv5_2 VSS 5V C_MD4_Inv5_C VSS MD4_Nor2_1 1p
S_MD4_Inv5_P MD4_Inv5_2 MD4_Nor2_1 MD4_Inv5_1 VSS _MD4_Inv5_P RS_MD4_Inv5_P MD4_Inv5_1 VSS 1G .MODEL _MD4_Inv5_P VSWITCH Roff=1e6 Ron=1 Voff=4.9V Von=0.1V S_MD4_Inv5_N MD4_Nor2_1 VSS MD4_Inv5_1 VSS _MD4_Inv5_N RS_MD4_Inv5_N MD4_Inv5_1 VSS 1G .MODEL _MD4_Inv5_N VSWITCH Roff=1e6 Ron=1 Voff=0.1V Von=4.9V V_MD4_Nor2_V MD4_Nor2_3 VSS 5V S_MD4_Nor2_P1 MD4_Nor2_3 MD4_Nor2_4 MD4_Nor2_1 VSS _MD4_Nor2_P1 RS_MD4_Nor2_P1 MD4_Nor2_1 VSS 1G .MODEL _MD4_Nor2_P1 VSWITCH Roff=1e6 Ron=1 Voff=4.9 Von=0.1 S_MD4_Nor2_P2 MD4_Nor2_4 MD4_Inv6_1 MD4_Nor2_2 VSS _MD4_Nor2_P2 RS_MD4_Nor2_P2 MD4_Nor2_2 VSS 1G .MODEL _MD4_Nor2_P2 VSWITCH Roff=1e6 Ron=1 Voff=4.9 Von=0.1 S_MD4_Nor2_N1 MD4_Inv6_1 VSS MD4_Nor2_2 VSS _MD4_Nor2_N1 RS_MD4_Nor2_N1 MD4_Nor2_2 VSS 1G .MODEL _MD4_Nor2_N1 VSWITCH Roff=1e6 Ron=1 Voff=0.1 Von=4.9 S_MD4_Nor2_N2 MD4_Inv6_1 VSS MD4_Nor2_1 VSS _MD4_Nor2_N2 RS_MD4_Nor2_N2 MD4_Nor2_1 VSS 1G .MODEL _MD4_Nor2_N2 VSWITCH Roff=1e6 Ron=1 Voff=0.1 Von=4.9 V_MD4_Inv6_V MD4_Inv6_2 VSS 5V C_MD4_Inv6_C VSS MD4_Inv6_3 1p
S_MD4_Inv6_P MD4_Inv6_2 MD4_Inv6_3 MD4_Inv6_1 VSS _MD4_Inv6_P RS_MD4_Inv6_P MD4_Inv6_1 VSS 1G .MODEL _MD4_Inv6_P VSWITCH Roff=1e6 Ron=1 Voff=4.9V Von=0.1V S_MD4_Inv6_N MD4_Inv6_3 VSS MD4_Inv6_1 VSS _MD4_Inv6_N RS_MD4_Inv6_N MD4_Inv6_1 VSS 1G .MODEL _MD4_Inv6_N VSWITCH Roff=1e6 Ron=1 Voff=0.1V Von=4.9V R_MD4_R1 VS VB 120k TC=-0.00135415, -2.516e-7 S_MD4_OHS_P VB MD4_OHS_2 MD4_OHS_1 com _MD4_OHS_P RS_MD4_OHS_P MD4_OHS_1 com 1G .MODEL _MD4_OHS_P VSWITCH Roff=1e9 Ron=1m Voff=4.9 Von=0.1 S_MD4_OHS_N MD4_OHS_3 VS MD4_OHS_1 com _MD4_OHS_N RS_MD4_OHS_N MD4_OHS_1 com 1G .MODEL _MD4_OHS_N VSWITCH Roff=1e9 Ron=1m Voff=0.1 Von=4.9 R_MD4_OHS_R6 HO MD4_OHS_2 11.4 TC=0.00190676, 9.3240e-07 R_MD4_OHS_R7 MD4_OHS_3 HO 7.76 TC=0.00241396, 2.331e-06 C_MD3_C1 com MD3_DlyHS_8 10p
C_MD3_C2 com MD3_DlyLS_8 10p
E_MD3_ABM21 MD3_DlyHS_1 com VALUE { ( V(VB)
+ -V(VS) ) } C_MD3_DlyHS_C VSS MD3_DlyHS_5 10n
S_MD3_DlyHS_delay_P MD3_DlyHS_20 MD3_DlyHS_5 MD3_DlyHS_2 VSS + _MD3_DlyHS_delay_P RS_MD3_DlyHS_delay_P MD3_DlyHS_2 VSS 1G .MODEL _MD3_DlyHS_delay_P VSWITCH Roff=1e6 Ron=10 Voff=4.99V Von=0.01V S_MD3_DlyHS_delay_N MD3_DlyHS_5 VSS MD3_DlyHS_2 VSS _MD3_DlyHS_delay_N RS_MD3_DlyHS_delay_N MD3_DlyHS_2 VSS 1G .MODEL _MD3_DlyHS_delay_N VSWITCH Roff=1e6 Ron=10 Voff=0.01V Von=4.99V S_MD3_DlyHS_P1 MD3_DlyHS_10 MD3_DlyHS_11 MD3_DlyHS_6 VSS _MD3_DlyHS_P1 RS_MD3_DlyHS_P1 MD3_DlyHS_6 VSS 1G .MODEL _MD3_DlyHS_P1 VSWITCH Roff=1e6 Ron=1 Voff=4.9V Von=0.1V S_MD3_DlyHS_P2 MD3_DlyHS_11 MD3_DlyHS_9 MD3_DlyHS_8 VSS _MD3_DlyHS_P2 RS_MD3_DlyHS_P2 MD3_DlyHS_8 VSS 1G .MODEL _MD3_DlyHS_P2 VSWITCH Roff=1e6 Ron=1 Voff=4.9V Von=0.1V S_MD3_DlyHS_N1 MD3_DlyHS_9 VSS MD3_DlyHS_8 VSS _MD3_DlyHS_N1 RS_MD3_DlyHS_N1 MD3_DlyHS_8 VSS 1G .MODEL _MD3_DlyHS_N1 VSWITCH Roff=1e6 Ron=1 Voff=0.1V Von=4.9V S_MD3_DlyHS_MP1 MD3_DlyHS_12 MD3_DlyHS_13 MD3_DlyHS_9 VSS + _MD3_DlyHS_MP1 RS_MD3_DlyHS_MP1 MD3_DlyHS_9 VSS 1G .MODEL _MD3_DlyHS_MP1 VSWITCH Roff=1e6 Ron=1 Voff=4.9V Von=0.1V S_MD3_DlyHS_MP2 MD3_DlyHS_13 MD3_DlyHS_8 MD3_DlyHS_7 VSS _MD3_DlyHS_MP2 RS_MD3_DlyHS_MP2 MD3_DlyHS_7 VSS 1G .MODEL _MD3_DlyHS_MP2 VSWITCH Roff=1e6 Ron=1 Voff=4.9 Von=0.1 S_MD3_DlyHS_MN1 MD3_DlyHS_8 VSS MD3_DlyHS_7 VSS _MD3_DlyHS_MN1 RS_MD3_DlyHS_MN1 MD3_DlyHS_7 VSS 1G .MODEL _MD3_DlyHS_MN1 VSWITCH Roff=1e6 Ron=1 Voff=0.1 Von=4.9 S_MD3_DlyHS_MN2 MD3_DlyHS_8 VSS MD3_DlyHS_9 VSS _MD3_DlyHS_MN2 RS_MD3_DlyHS_MN2 MD3_DlyHS_9 VSS 1G .MODEL _MD3_DlyHS_MN2 VSWITCH Roff=1e6 Ron=1 Voff=0.1 Von=4.9 X_MD3_DlyHS_Comp1 MD3_DlyHS_5 MD3_DlyHS_18 MD3_DlyHS_7 com COMP X_MD3_DlyHS_Comp2 MD3_DlyHS_3 MD3_DlyHS_5 MD3_DlyHS_6 com COMP E_MD3_DlyHS_ABM5 MD3_DlyHS_21 com VALUE { (5-5*EXP(-{toffT2}/10/10n))
+ (5-5 EXP(-( {toffT1}+({toffT3}-{toffT1})/({T3}-{T1})(TEMP-{T1}))/10/10n)) +
+ /(5-5
EXP(-( {toffT1}+({toffT3}-{toffT1})/({T3}-{T1})({T2}-{T1}))/10/10n)) + } E_MD3_DlyHS_ABM14 MD3_DlyHS_19 com VALUE { (1-EXP(-( {toffVdd1}+( + {toffVdd3}-{toffVdd1})/({V3}-{V1})(V(VDD)-{V1}))/10/ 10n))/
+ (1-EXP(-( {toffVdd1}+({toffVdd3}-{toffVdd1})/({V3}-{V1})*({V2} -{V1}))/10/ + 10n)) } E_MD3_DlyHS_ABM31 MD3_DlyHS_18 com VALUE { ( V(MD3_DlyHS_21)
+ *V(MD3_DlyHS_17)
+ V(MD3_DlyHS_19) ) } E_MD3_DlyHS_ABM24 MD3_DlyHS_3 com VALUE { (EXP(-({tonVdd1}+({tonVdd3}- + {tonVdd1})/({V3}-{V1})(V(VDD)-{V1}))/10/10n))/((EXP(-({tonVdd1}+({tonVdd3}- + {tonVdd1})/({V3}-{V1})*({V2}- {V1}))/10/10n)))
+ (5 EXP(-( {tonT1}+({tonT3}-{tonT1})/({T3}-{T1})(TEMP-{T1})) /10/ + 10n))/(5 EXP(-( {tonT1}+({tonT3}-{tonT1})/({T3}-{T1})*({T2}-{T1})) /10/ + 10n))*5*EXP(-{tonT2}/10/10n)* (EXP(-({tonV1}+({tonV3}-{tonV1})/({V3}- + {V1})(V(MD3_DlyHS_1)-{V1}))/10/10n))/((EXP(-( {tonV1}+({tonV3}-{tonV1})/({V3}- + {V1})({V2}-{V1}))/10/10n))) } V_MD3_DlyHS_V_delay MD3_DlyHS_20 VSS 5V C_MD3_DlyHS_C3 VSS MD3_DlyHS_6 10p
V_MD3_DlyHS_VC1 MD3_DlyHS_10 VSS 5V C_MD3_DlyHS_C6 VSS MD3_DlyHS_9 10p IC=-5V C_MD3_DlyHS_C5 VSS MD3_DlyHS_8 10p IC=0V V_MD3_DlyHS_VC2 MD3_DlyHS_12 VSS 5V S_MD3_DlyHS_N2 MD3_DlyHS_9 VSS MD3_DlyHS_6 VSS _MD3_DlyHS_N2 RS_MD3_DlyHS_N2 MD3_DlyHS_6 VSS 1G .MODEL _MD3_DlyHS_N2 VSWITCH Roff=1e6 Ron=1 Voff=0.1V Von=4.9V C_MD3_DlyHS_C4 VSS MD3_DlyHS_7 10p
E_MD3_DlyHS_ABM13 MD3_DlyHS_17 com VALUE { (1-EXP(-( {toffV1}+({toffV3}- + {toffV1})/({V3}-{V1})((V(MD3_DlyHS_1))-{V1}))/10/ 10n))/
+ (1-EXP(-( {toffV1}+({toffV3}-{toffV1})/({V3}-{V1})
({V2} -{V1}))/10/ 10n)) + } C_MD3_DlyLS_C VSS MD3_DlyLS_5 10n
S_MD3_DlyLS_delay_P MD3_DlyLS_20 MD3_DlyLS_5 MD3_DlyLS_2 VSS + _MD3_DlyLS_delay_P RS_MD3_DlyLS_delay_P MD3_DlyLS_2 VSS 1G .MODEL _MD3_DlyLS_delay_P VSWITCH Roff=1e6 Ron=10 Voff=4.99V Von=0.01V S_MD3_DlyLS_delay_N MD3_DlyLS_5 VSS MD3_DlyLS_2 VSS _MD3_DlyLS_delay_N RS_MD3_DlyLS_delay_N MD3_DlyLS_2 VSS 1G .MODEL _MD3_DlyLS_delay_N VSWITCH Roff=1e6 Ron=10 Voff=0.01V Von=4.99V S_MD3_DlyLS_P1 MD3_DlyLS_10 MD3_DlyLS_11 MD3_DlyLS_6 VSS _MD3_DlyLS_P1 RS_MD3_DlyLS_P1 MD3_DlyLS_6 VSS 1G .MODEL _MD3_DlyLS_P1 VSWITCH Roff=1e6 Ron=1 Voff=4.9V Von=0.1V S_MD3_DlyLS_P2 MD3_DlyLS_11 MD3_DlyLS_9 MD3_DlyLS_8 VSS _MD3_DlyLS_P2 RS_MD3_DlyLS_P2 MD3_DlyLS_8 VSS 1G .MODEL _MD3_DlyLS_P2 VSWITCH Roff=1e6 Ron=1 Voff=4.9V Von=0.1V S_MD3_DlyLS_N1 MD3_DlyLS_9 VSS MD3_DlyLS_8 VSS _MD3_DlyLS_N1 RS_MD3_DlyLS_N1 MD3_DlyLS_8 VSS 1G .MODEL _MD3_DlyLS_N1 VSWITCH Roff=1e6 Ron=1 Voff=0.1V Von=4.9V S_MD3_DlyLS_MP1 MD3_DlyLS_12 MD3_DlyLS_13 MD3_DlyLS_9 VSS + _MD3_DlyLS_MP1 RS_MD3_DlyLS_MP1 MD3_DlyLS_9 VSS 1G .MODEL _MD3_DlyLS_MP1 VSWITCH Roff=1e6 Ron=1 Voff=4.9V Von=0.1V S_MD3_DlyLS_MP2 MD3_DlyLS_13 MD3_DlyLS_8 MD3_DlyLS_7 VSS _MD3_DlyLS_MP2 RS_MD3_DlyLS_MP2 MD3_DlyLS_7 VSS 1G .MODEL _MD3_DlyLS_MP2 VSWITCH Roff=1e6 Ron=1 Voff=4.9 Von=0.1 S_MD3_DlyLS_MN1 MD3_DlyLS_8 VSS MD3_DlyLS_7 VSS _MD3_DlyLS_MN1 RS_MD3_DlyLS_MN1 MD3_DlyLS_7 VSS 1G .MODEL _MD3_DlyLS_MN1 VSWITCH Roff=1e6 Ron=1 Voff=0.1 Von=4.9 S_MD3_DlyLS_MN2 MD3_DlyLS_8 VSS MD3_DlyLS_9 VSS _MD3_DlyLS_MN2 RS_MD3_DlyLS_MN2 MD3_DlyLS_9 VSS 1G .MODEL _MD3_DlyLS_MN2 VSWITCH Roff=1e6 Ron=1 Voff=0.1 Von=4.9 X_MD3_DlyLS_Comp1 MD3_DlyLS_5 MD3_DlyLS_18 MD3_DlyLS_7 com COMP X_MD3_DlyLS_Comp2 MD3_DlyLS_3 MD3_DlyLS_5 MD3_DlyLS_6 com COMP E_MD3_DlyLS_ABM5 MD3_DlyLS_21 com VALUE { (5-5*EXP(-{toffT2}/10/10n))
+ /(5-5
EXP(-( {toffT1}+({toffT3}-{toffT1})/({T3}-{T1})({T2}-{T1}))/10/10n)) + } E_MD3_DlyLS_ABM14 MD3_DlyLS_19 com VALUE { (1-EXP(-( {toffVdd1}+( + {toffVdd3}-{toffVdd1})/({V3}-{V1})(V(VDD)-{V1}))/10/ 10n))/
+ (1-EXP(-( {toffVdd1}+({toffVdd3}-{toffVdd1})/({V3}-{V1})*({V2} -{V1}))/10/ + 10n)) } E_MD3_DlyLS_ABM31 MD3_DlyLS_18 com VALUE { ( V(MD3_DlyLS_21)
+ *V(MD3_DlyLS_17)
+ V(MD3_DlyLS_19) ) } E_MD3_DlyLS_ABM24 MD3_DlyLS_3 com VALUE { (EXP(-({tonVdd1}+({tonVdd3}- + {tonVdd1})/({V3}-{V1})(V(VDD)-{V1}))/10/10n))/((EXP(-({tonVdd1}+({tonVdd3}- + {tonVdd1})/({V3}-{V1})*({V2}- {V1}))/10/10n)))
+ (5 EXP(-( {tonT1}+({tonT3}-{tonT1})/({T3}-{T1})(TEMP-{T1})) /10/ + 10n))/(5 EXP(-( {tonT1}+({tonT3}-{tonT1})/({T3}-{T1})*({T2}-{T1})) /10/ + 10n))*5*EXP(-{tonT2}/10/10n)* (EXP(-({tonV1}+({tonV3}-{tonV1})/({V3}- + {V1})(V(VC)-{V1}))/10/10n))/((EXP(-( {tonV1}+({tonV3}-{tonV1})/({V3}-{V1})( + {V2}-{V1}))/10/10n))) } V_MD3_DlyLS_V_delay MD3_DlyLS_20 VSS 5V C_MD3_DlyLS_C3 VSS MD3_DlyLS_6 10p
V_MD3_DlyLS_VC1 MD3_DlyLS_10 VSS 5V C_MD3_DlyLS_C6 VSS MD3_DlyLS_9 10p IC=-5V C_MD3_DlyLS_C5 VSS MD3_DlyLS_8 10p IC=0V V_MD3_DlyLS_VC2 MD3_DlyLS_12 VSS 5V S_MD3_DlyLS_N2 MD3_DlyLS_9 VSS MD3_DlyLS_6 VSS _MD3_DlyLS_N2 RS_MD3_DlyLS_N2 MD3_DlyLS_6 VSS 1G .MODEL _MD3_DlyLS_N2 VSWITCH Roff=1e6 Ron=1 Voff=0.1V Von=4.9V C_MD3_DlyLS_C4 VSS MD3_DlyLS_7 10p
E_MD3_DlyLS_ABM13 MD3_DlyLS_17 com VALUE { (1-EXP(-( {toffV1}+({toffV3}- + {toffV1})/({V3}-{V1})((V(VC))-{V1}))/10/ 10n))/
.ENDS IR2110
.SUBCKT COMP 1 2 3 4 E1 5 4 VALUE={IF((V(1)>V(2)), V(4)+5V, V(4))} R1 5 3 1 C1 3 4 10P .ENDS
then after some reading I've think that apparently the lines with the definitions are the problem and I beleive that are specially those that have the "+" sign juste after the definition of the name and and definitions of the pins but a can't be shure.
I'm actually reusing the model of the IR2112 which has the pin asignment and package defined but I don't know how to manage some of the parameters of the plus lines.
I know with the model of the IR2112 I could work but: Can anyone help me with this problem?, is a way of learning more of proteus better said spice.
Thanks in advance for the help.
I've forgot to tell that the property SPACEPINS of the model in proteus is written this way: VDD,HIN,SD,LIN,VSS,HO,VB,VS,VC,COM,LO; the same order of the spice model.
Nevermind, I've found in labcenter's forum that this model isn't compatible in all parameters with the spice simulator of proteus, then I need to modify it and that specific task is a work that I don't need to do right now so I'm simulating it with the IR2112 which has similar charecteristics.
