I have a motorcycle with an SAE 12v 10ga lead for charging that I'd also like to occasionally jump-start the motorcycle with, I need about 90amps for about 1 second, which is fine for the 10ga wire, but not fine for the 30amp inline ATC fuse.
Do they make slow-blow fuses for ATC that would allow momentarily 90amps, but break on sustained 30amps? I don't want to risk of fire and I don't want to bypass the fuse entirely.
Must I go Direct?
Edit, I found "Flosser Micro FMM Mcase Fuse" that are slow-blow 30Amp fuses, but cannot find an inline holder, that may be the answer I need but still unable to source the parts.
  • \$\begingroup\$ No kick-start pedal? \$\endgroup\$
    Apr 25, 2020 at 8:06
  • \$\begingroup\$ lol, no 2300cc Rocket 3 \$\endgroup\$ Apr 25, 2020 at 12:55
The correct answer was to replace the battery so I don't have to design something to jump it each time I want to ride it.
Direct wire also allowed it to be jumped but increased the danger of fire if the POS (not exposed) terminal was grounded.
