Novice here, sorry if I'm missing something obvious.
I'm trying to drive 4 strips of 6 low-power RGB LEDs each (APF3236LSEEZGKQBKC) on a 3.3V battery. I have a 12-channel LED Driver (TLC6C5912) which seem perfect for the job.
However, voltage is an issue, as each green or blue channel could need up to about 20V depending on the brightness I settle for. A DC/DC boost converter seems to be the way to go to get 20V bursts out of my little battery, but from what I know, I should drive LEDs by constant current, not constant voltage, in order to account for brightness variations and possible damage due to temperature rises. I was thinking something like the TPS61096A.
Should I use something else than a DC/DC boost converter? Or add something to it to control the current?
