I know what pinch off voltage is.It is the gate-source voltage at which drain current is cut off completely (pinched off) is called the pinch-off voltage.
But what is pinched off current?
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityI know what pinch off voltage is.It is the gate-source voltage at which drain current is cut off completely (pinched off) is called the pinch-off voltage.
For any particular gate-source bias voltage, when the drain-source voltage reaches a certain value, the characteristic of drain-source voltage vs drain current becomes a near-straight horizontal line. This is the "pinched-off" current and it is near constant with changes to drain-source voltage.
Picture taken from this quora page for convenience.
Here's another picture showing the characteristic with different gate bias voltages but this time it's for a JFET (hence negative gate voltages with respect to source): -
