I was going through some power supplies for my LED Lighting project and found an inrush current of 30A/115V in the datasheet. My questions are:
Will it trip my home circuit breaker?
How long does the inrush current last?
What does cold start mean in power supply? enter image description here
“Will it trip by circuit breaker?”
Probably not. You need to check the characteristic of your particular breaker to tell for sure, but the most commonly installed do have some time-lag for this very purpose. Since you mention 115 V, I assume you are in North America. I don’t know how they are marked there but on this side of the pond they come in “speeds” A-D, with C being the most common. enter image description here
“How long does the inrush current last?”
It should last some tens of ms or a few cycles. enter image description here
“What does cold start mean in a power supply?”
Cold start means your power supply is completely deenergized, say 30 seconds after you have turned it off. A hot start on the other hand would be flicking it off and then on in rapid succession.
Sounds normal for a switching mode power supply.
Cold start means there is inrush current limiter (NTC thermistor) that has high resistance when cold. If you unplug the unit and replug it without letting it cool again, the inrush current will be higher.
