[NOTE] I understand that the adapter that I bought for my battery pack is not actually a charger. I also understand that it could be dangerous what I'm doing. I still wonder why there is no current flowing from the adapter towards the battery pack though. If anybody could help me find an answer to that question I'd be very grateful. [/NOTE]
I'm building an autonomous boat, and for this I was using this 12V Li-ion battery pack which came with a very simple charger:
This works great, but since I'll need a very specific form of battery (long and thin to fit in my boat) I decided I need to built my own battery pack. From this other project I got the idea that if I use an 18V solar panel I can build a 5S LiFePo4 battery pack which means I will not need a solar charge controller. His reasoning is as follows:
The behavior of a solar panel connected directly to a battery is similar to your typical CC-CV lithium battery charger: a lot of current until the battery gets close to fully charged, and then the voltage rises while the current decreases (the solar panel will put out less current as the voltage rises). TO put numbers to this, the Renogy solar panel's max power voltage is 17.7 volts (depending on temperature) and the 5-cell LiFePo4 battery's nominal voltage is 16 volts and its fully-charged voltage is 18 volts.
By not needing a charge controller I would save on complexity, money and most importantly: space in the boat. So if possible I would like to avoid using a charge controller.
So I bought 10 of these LiFePO4 18650 batteries and this 5S balancing BMS and hooked it up in this 5S2P test setup:
Since I don't have the solar panels yet I bought this simple 18V 2A charger:
The batteries came all charged at exactly 3.33V. So after soldering together my battery pack I attached it to my boat. It worked and I left it on for a while. When I came back to it after about an hour the boat shut down. I checked the battery cells and their voltage was 2.8V (way too low). I then attached it to the charger and let it charge for a day or so. When I came back to test it, the battery didn't seem to have charged at all though. It was only charged up to 2.85V per cell.
I then attached a watt meter between the charger and the battery pack, and that showed me an input voltage from the charger of 18.3V, but no current flowing:
This explains why the battery isn't charged, but I wonder why this is happening? The only reason I can think of is that the BMS is blocking any incoming current, either because the voltage supplied by the charger is too high OR because the battery voltage is too low. I checked out the specs of the BMS (pasted below) and in there it says the "Single Overcharge Protection Voltage" is 3.75V, which means the supplied 3.66V (18.3V / 5) from the charger is within limits, but very close.
Am I right in my thinking that the voltage of the charger is too high? And if the voltage is too high, would it work if I simply reduce it by for example 1V? Or can I built in some kind of thing that caps the voltage at 18V or 17.5V or something?
Again; I understand I need a proper charger instead of this adapter. But I would like to understand the reason why there is no current flowing. Would anybody know how I can test/debug this? All tips are welcome!
    \$\begingroup\$ What you bought is not a charger. Use a proper charger to avoid your boat catching fire and sinking. Do some research into this - I mean where were you with all the samsung phone batteries were killing folk? \$\endgroup\$
    Apr 26, 2020 at 15:36
  • \$\begingroup\$ @Andyaka - Could you elaborate on that? Why would the li-ion be fine with a regular 12.6 supplied voltage but the LiFePO4 not? \$\endgroup\$
    – kramer65
    Apr 26, 2020 at 15:51
    \$\begingroup\$ It's pretty clear what I said - what is it that you don't understand? \$\endgroup\$
    Apr 26, 2020 at 15:53
    \$\begingroup\$ Just because you are not prevented from doing something does not mean it is fine. An 18V, 2A AC-DC adapter is NOT a charger, You called it a charger, but it is NOT a charger. I repeat it is NOT a charger. Also, there appears to be zero balancing on both batteries. \$\endgroup\$
    – DKNguyen
    Apr 26, 2020 at 16:11
    \$\begingroup\$ Same thing as with your cell phone. The charger for the battery is in the phone. The black thing that connects to mains voltage is just a power supply, not a charger. Connecting a power supply directly to battery is dangerous. \$\endgroup\$
    – Justme
    Apr 26, 2020 at 16:12
There is no detailed manual for the BMS board, so it could work as it is supposed to, but we just don't know how it is supposed to work.
So this question may not be answerable - we can't know but we can guess.
It clearly has latched into a state that the 18V 2A supply is disconnected from the battery. But what we don't know how it ends up in that situation, whether the BMS is already cutting the battery off, or does it only trigger the cut-off when the 12V 2A supply is connected, and continues cut-off until it is removed.
One guess is that when the 18V 2A power supply was connected to the empty battery pack with about 14V, the pack will load down the power supply output to 14V and will draw more than the 2A it can supply, so the power supply output undervoltage/overcurrent protection triggers in and shuts down. That may have also caused current to flow from batteries to the power supply, so the BMS may have triggered some protection to cut off the batteries from the supply, and it will be cut off until charger voltage is removed.
Another guess is that the BMS considers the batteries drained and has cut off the batteries permanently, so no current can go in or out from the battery now, until they are trickle charged to exceed the cut-off voltage.
You would really have to present more data to know what is happening, for example if you had an oscilloscope, you could probe what happens when you connect the two together.
Except that you should not be connecting them together in the first place, and the BMS has maybe performed it's job to prevent catastrophic failure with flames and explosions.
  • \$\begingroup\$ Thanks for the thoughts. I'm going to dis-assemble this whole thing and rethink it. One more question. What would you want to measure with the oscilloscope? How would you approach this problem in general? Even though I failed building this battery pack, I'm trying to learn as much as possible from my failure. \$\endgroup\$
    – kramer65
    May 7, 2020 at 12:20
  • \$\begingroup\$ Since you asked why it does not charge, one thing that can show you why it does not charge is an oscilloscope. It can show you how the voltages change in the following microseconds or milliseconds after you connect the power supply instead of charger. It can help you determine whether it is the BMS board that starts to protect the battery, or the power supply that starts to protect itself, or something different. \$\endgroup\$
    – Justme
    May 7, 2020 at 12:34
