17:24:45 **** Programming project STM32_HelloWorld on chip ****
"C:\\Ac6\\SystemWorkbench\\plugins\\fr.ac6.mcu.externaltools.openocd.win32_1.23.0.201904120827\\tools\\openocd\\bin\\openocd.exe" -f stm32.flash.6462756934245305845.cfg -s "C:\\Users\\nvenk\\Workspace\\RTOS_workspace\\STM32_HelloWorld" -s "C:\\Ac6\\SystemWorkbench\\plugins\\fr.ac6.mcu.debug_2.5.0.201904120827\\resources\\openocd\\st_scripts" -c "program Debug/STM32_HelloWorld.elf verify reset " -c shutdown
Open On-Chip Debugger 0.10.0+dev-00021-g524e8c8 (2019-04-12-08:48)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
srst_only separate srst_nogate srst_open_drain connect_assert_srst
Info : The selected transport took over low-level target control. The results might differ compared to plain JTAG/SWD
adapter speed: 8000 kHz
adapter_nsrst_delay: 100
Info : clock speed 8000 kHz
Error: libusb_open() failed with LIBUSB_ERROR_ACCESS
Error: open failed (no matching adapter found)
in procedure 'program'
in procedure 'init' called at file "embedded:startup.tcl", line 495
in procedure 'ocd_bouncer'
** OpenOCD init failed **
shutdown command invoked
17:24:46 Build Finished (took 201ms)
Also I do have drivers installed for stm32 board. copy pasted screen shot of my device manager below. Please help me. enter image description here
    \$\begingroup\$ I've rejected your edit of my answer. Please update your question instead if you have additional information about your problem. \$\endgroup\$
    – Codo
    Apr 27, 2020 at 9:44
From the log I can see that you are using OpenOCD to upload the firmware. OpenOCD doesn't use the propriertary STM drivers but the libusb. That's the cause of the error:
To fix it, you will need to install a tool called Zadig.
In Zadig:
  1. Check Options / List all devices
  2. Select the STLink in the upper combobox
  3. Select libusbK in the combox box on the right hand side of the arrow
  4. Click Install Driver
After the installation, it should display libusbK on the left hand side of the arrow as well.
  • \$\begingroup\$ Thanks for your response. \$\endgroup\$
    – Raj
    Apr 27, 2020 at 9:06
