During this lockdown I had some time in hand and decided to learn more about impedance. So I gave myself a project, trying to create a impedance graph in excel base on a the schematic seen above. The passive components will be a variable.
To do that, I first need to derive the impedance equation for the schematic seen above. When I cross check it with a simulation tool and a proven graph, I could not get the graph to match. Hence, I believe I must have done something wrong. I had doubled, tripled checked and corrected all the mistakes.
I do not know where I went wrong. I am hoping if I can get a 2nd or 3rd eye to look to see where I might have gone wrong.
This is my first post here, I had done the search but to no avail of information I can obtain anymore. Do let me know if I did violate any rules by posting this.
Edit: I have removed my derivation, as it is wrong and not working. This is to not confuse other readers as User Verbal Kint has provided a really good solution.
  • \$\begingroup\$ That's a cranky way of doing things. \$\endgroup\$ – Andy aka Apr 28 at 14:25
  • \$\begingroup\$ This would all be easier for you if you worked with a numerical analysis tool that can handle complex numbers instead of using Excel and having to do all that algebra yourself. For example: Matlab, Octave, Numpy, Maple, Mathematica, ... \$\endgroup\$ – The Photon Apr 28 at 14:31
  • \$\begingroup\$ I am not sure you can obtain a tractable result using this approach. I would highly recommend the FACTs to get there. You have a 3rd-order denominator and a 2nd-order numerator as a first observation. \$\endgroup\$ – Verbal Kint Apr 28 at 14:35
  • \$\begingroup\$ Or use an algebraic tools like Maple, Maxima, ... \$\endgroup\$ – Huisman Apr 28 at 14:37
  • \$\begingroup\$ Z1 (first half page) seems right to me. Why do conjugate this afterwards? \$\endgroup\$ – Stefan Wyss Apr 28 at 15:56
There are several ways to look at this type of 3rd-order transfer function: brute-force analysis - which often leads to algebraic paralysis - and the fast analytical techniques or FACTs.
The brute-force expression is not that complicated to write but good luck to develop it and express the result as a meaningful transfer function. Fortunately, it is easy to plot it with a mathematical solver like Mathcad:
With the FACTs (or any other approach), you determine this transfer function (yes, an impedance is a transfer function) by installing a test generator \$I_T\$ - the stimulus - across the connecting terminals and determine the response \$V_T\$ that it generates. To determine the denominator, you turn the excitation off (the current source is zeroed or open-circuited) and you "look" through the connecting terminals of the 3 energy-storing elements to determine the resistance \$R\$ that drives them. They are temporarily removed during this exercise. This is to write the denominator \$D(s)=1+sb_1+s^2b_2+s^3b_3\$.
For the zeroes, you null the response across the current source \$I_T\$ meaning that you replace it by a short circuit (this is a degenerate case). Again, you "look" through the connecting terminals of the 3 energy-storing elements to determine the resistance \$R\$ that drives them. This is to write the numerator \$N(s)=1+sb_1+s^2b_2\$. There is no third-order coefficient as \$C_3\$ is shorted in this exercise.
If you draw intermediate sketches and write carefully all the time constants, without a single line of algebra, then you assemble the transfer function at the end:
Finally, you can plot this expression and compare its response versus that of the brute-force formula used a reference here:
If you now want to extract the magnitude and phase expressions, I let you replace \$s\$ by \$j\omega\$ and collect real and imaginary terms. I'm done for tonight : )
Addendum
If you want the phase and the magnitude of this transfer function, below are the expressions to compute them:
| improve this answer | |
