I have an incremental rotary encoder (Bournes-EMS22Q) that I would like to have available on a wired network via RJ45 or via serial TTL (we have a serial-to-ethernet converter we can use Netburner SBL2E). This seems like a fairly simple problem however the more I look into it the more complex it gets, there doesn't seem to be an off-the-shelf solution and it looks like I'll have to make something myself.
Has anyone come across this problem before? How can I get from the encoder output (5 pin) to serial/ethernet?
I'm now looking at a chip-level solution using this 32-bit Quaderature Counter which gives me an SPI output but how do I go from SPI in this case to serial TTL/Ethernet? Will I need to use a microcontroller?
Is there a magical hardware component that I'm missing? Any recommendations on how to solve this problem greatly appreciated.
    \$\begingroup\$ your question has nothing to do with IOT \$\endgroup\$
    – jsotola
    Apr 28, 2020 at 18:58
  • \$\begingroup\$ I guess.... but I need to be able to access its output over a network \$\endgroup\$
    – AVD
    Apr 28, 2020 at 19:41
  • \$\begingroup\$ it seems to me that your question is about using a microcontroller to read the signals from the rotary encoder ... what you do with the data afterwards is a separate issue \$\endgroup\$
    – jsotola
    Apr 28, 2020 at 19:54
You need a microcontroller and custom firmware to read and interpret the encoder then transmit the message over serial. In essence, you have to do it manually. No magic pre-packaged solution.
If unfamiliar with microcontrollers, you can try a PICAXE or Arduino.
  • \$\begingroup\$ Thanks, I've been going crazy trying to find a prepackaged solution. Looks like I'll need to bite the bullet and get my hands dirty. \$\endgroup\$
    – AVD
    Apr 28, 2020 at 19:44
