I have some troubles to understand the above circuit :
The goal is to discharge the capacitor which was previously charged to 20V the most rapidly. (At least I think). The collector emitter voltage drop of the phototransitor and the forward diode voltage have to share the voltage of the discharging capacitor. At the beginning of the discharge, ie when the voltage of the capacitor is equal to 20V, the diode forward voltage is equal to Vf (lower than 1V), so VCE has to be equal to at least 19V ! So if VCE is high, the collector current Ic of the phototransitor is limited by the gain of the phototransitor and the forward current of the emitter diode $$If*CTR = Ic$$ where CTR is the current transfer ratio. So for discharging the most rapidly the capacitor, we have to have a high collector current, ie a high forward current flowing through the emmitter diode. What do you think ? Wouldn't be better if a resistor would be added in series with the phototransitor ? It will allow to saturate the photransitor without necessary diminishing the collector current if the forward current is high.
By the way I did not get why there is a shunt resistor R2. It will reduce If. Nevertheless it could help to reduce noise problem. (leakage current will not be a problem, isn't it ?) Wouldn't be better if the shunt resistor would be placed as a pull down resistor. Same thing for the capacitor next to the shunt resistor? This capacitor will slow down the discharge of the capacitor charged to 20V. What do you think ?
Thank you very much and have a nice day :)
