Question
Three capacitor with \$C=100\mu F\$ and \$50V\$ are series connected,and connected with the \$10V\$ voltage source,what is the equivalent capacitance of this circuit?
Method 1
\$C_{eq}=100\mu//100\mu//100\mu=\frac{100\mu}{3}=33.3\mu F\$
Method 2
The question circuit is as below
\$C_{eq}=\frac{Q_t}{V}\$,and \$Q_t=\sum\limits^3_{i=1}C_iV_i\$,
\$V_1:V_2:V_3=\frac{1}{C_1}:\frac{1}{C_2}:\frac{1}{C_2}=1:1:1,so V_1=V_2=V_3=3.33V\$
So \$Q_t=\sum\limits^3_{i=1}C_iV_i=3\times 100\mu \times 3.33=1000\mu=1m\$,
so \$C_{eq}=\frac{Q_t}{V}=\frac{1m}{10V}=0.1mF\$
However,obviously we can know the answer from the method 2 is wrong,but i don't know which step is the main reason that let me calculate to the wrong answer,where am i wrong in the method 2??Can anyone tell me??
The charge leaving the 10 volt source is basically the number of electrons that flow into the capacitors in order to charge them up. That movement of electrons is the same for all the capacitors and the source. Electrons are electrons and don't disappear.
So, the charge on each capacitor is the same as the total charge of the whole circuit. Charge is just the number of electrons and, the same number of electrons flow through all the series connected capacitors. If we were talking about three series connected resistors taking 1 amp, would you say that the total current is 3 amps?
So your mistake was in assuming that the total charge was 3 x the individual charge.
    \$\begingroup\$ @shineele This might help you understand why. \$\endgroup\$
    Apr 30, 2020 at 9:38
  • \$\begingroup\$ @shineele - are we done with this now or do you have further questions? \$\endgroup\$
    May 1, 2020 at 9:32
For a series connection of capacitors the current that flows through them is the same, therefore the charge in each of them is the same. Though the sum of voltages across each capacitor must equal to source voltage. That is:
\$Q=C_{eq}V\$ or \$V=\frac{Q}{C_{eq}}\$
\$V_1=\frac{Q}{C_1},V_2=\frac{Q}{C_2} ,V_3=\frac{Q}{C_3} \$.
But \$V=V_1+V_2+V_3\$
Substitute into this last equation and solve for \$C_{eq}\$.
