The device documentation related to the Cyclone 10 LP FPGA states that "you must power up VCCA even if the PLL is not used".
We were comparing the power dissipation of a Microsemi IGLOO2 FPGA with the Cyclone 10 LP. The core power dissipation of the Cyclone 10 LP was significantly lower than the IGLOO2. However, when we measured the VCCA we found that although we were using no PLLs in the design the power dissipation was quite huge on it. So eventually we gave up on the idea to use Cyclone 10 LP in place of the Flash based IGLOO2 FPGA.
Why is VCCA so important? Can't Intel make FPGAs where the device can work with VCCA grounded when PLLs are not being used?
