strong text
Can anyone please help me in understanding the output of this amplifier? According to me it is coming as (E1-E2)(1+(Rw/R)).
I am more curious about knowing wheather Rw will come in the output equation or not, and if not how will it get eliminated.
    \$\begingroup\$ Why not use a simulator? \$\endgroup\$
    May 1, 2020 at 9:03
  • \$\begingroup\$ How do you know that is an inst. amp? Instrumentation amplifiers normally have a single gain resistor, what you have shown looks more like a difference amplifier. \$\endgroup\$
    – Voltage Spike
    May 4, 2020 at 19:01
The presence of the BJT should not put you off because it's just an emitter follower AND is contained within the feedback loop (just are all the internal transistors in the signal chain inside the op-amp).
Using your resistor names the gain is: -
$$\dfrac{V_O}{E1 - E2} = \dfrac{R_W + R}{R}$$
That looks to be the same as your formula.
