has anyone ever attempted to measure servo torque using current? Basically if you have a robot you want to detect stall state and approximate force being applied.
\$\begingroup\$ I do this with big electric motors all the time (big meaning traction motors the size of small cars). In those motors current and torque are nearly linear. \$\endgroup\$ – Ron Beyer May 1 '20 at 23:22
\$\begingroup\$ What kind of servos? RC servos? It so it is not impossible but also not straightforward due to the way RC servos consume current. You won't be able to just detect when the current gets too high. You must inspect the current waveform itself. See this: rchelicopterfun.com/digital-servos.html \$\endgroup\$ – DKNguyen May 1 '20 at 23:22
\$\begingroup\$ Yes, RC servos. \$\endgroup\$ – FourierFlux May 1 '20 at 23:29
Yes. Motor torque is directly proportional to the current. In the case of a brushless motor, torque is proportional to the phase currents when expressed in a rotating reference frame. This principle is used often in robotics, especially when creating highly dynamic robots, and when used in combination with accurate and precise encoders, can be used even to estimate end effector forces. If your motor manufacturer does not provide you with the torque constant, you can easily obtain it by measuring the motor's velocity constant (the no-load motor speed in RPM divided by the voltage at that speed). The torque constant is proportional to the inverse of the velocity constant.
\$\begingroup\$ What about for standard RC servos though? \$\endgroup\$ – FourierFlux May 2 '20 at 21:11
\$\begingroup\$ you'll need to construct a motor driver with current sensor(s) on the motor phases to do this properly. easier for brushed than brushless \$\endgroup\$ – Ocanath May 2 '20 at 22:11
