7
I think that in many cases the voltage that a multimeter shows in diode mode is dependent on the current it uses for that mode. So the values measured by different multimeters in diode mode should be different in many cases. Am I right? If that's the case, why don't they make a universally accepted standard, so that all multimeters use the same amount of current in diode made and the measured values can be compared (which could be helpful in diagnostics)?
  • \$\begingroup\$ I have noticed a difference in the voltages used in different meters for diode mode. I have measured as low as 3.0vdc, and as high as 6vdc. This measurement is on 'open leads' of the VM under test by another meter. I can find nothing mentioning a standard or even suggestion for consistent voltage, which will directly influence multimeters and their results. \$\endgroup\$ Dec 27, 2021 at 1:43
14
Typical multimeter currents are about 1 mA, with a fair amount of variation, and this is not standardized that well, but it's not a massive issue given the exponential I-V characteristic of properly-functioning diodes under forward bias.
Furthermore, if I'm using a multimeter for a diode test, I'm not looking for a precise value anyway. Instead, I'm looking to see whether I am hitting a diode drop at all. In practice, if I really cared about my diode's saturation current, I'd grab something more precise than a multimeter.
The current in a forward-biased diode is given by:
$$I_D = I_S\cdot e^{\frac{V_F}{nV_T}} - 1$$
where \$V_T\$ is the thermal voltage (about 26 mV at room temperature) and \$n\$ is either one or two depending on semiconductor type. \$I_S\$ is a constant current associated with that diode and environmental conditions (e.g. temperature).
It follows from this math that the forward voltage of the diode will vary very little even for moderate differences in current; in the worst case (ideality factor of 2 corresponding to indirect bandgap semiconductors), a 10x difference in current between two meters will only yield a ~0.1 V discrepancy.
  • \$\begingroup\$ Thanks. I've seen that people use diode mode for testing and diagnosing complete boards not just for testing diodes (example). In that situation, the effect of current on measured voltage is usually more significant. \$\endgroup\$
    – apadana
    May 2, 2020 at 0:49
    \$\begingroup\$ @apadana In that case, you're still looking for a telltale near-constant voltage IV characteristic, likely associated with a diode (around 0.6-0.7 V) or schottky (around 0.2 or 0.3). If I wanted to do any more thorough testing, I would need to know more about the board anyway, to that point that (in my experience doing both diagnostics on my own designs as well as repair of boards) it's never been a major issue. \$\endgroup\$
    – nanofarad
    May 2, 2020 at 1:38
13
Some meters use a constant current, cheap meters more like a resistor to some odd voltage of around 1.5 to 3V. The current is typically around 1mA
In this answer I measured a few meters I had within reach, low short-circuit current was 0.51mA, high was 1.6. Low open-circuit voltage was 1.54, high 7V (most were around 3V).
Only the fancy Agilent benchtop used a high-compliance (7V) true constant current 1.00mA source.
There is no incentive for the makers of cheap meters to add extra cost and maybe power consumption when a 0.1 cent resistor works well enough for just about everyone.
Even with that 3:1 variation in test current, there is no question whether a diode is Schottky or a regular silicon diode.
As you can see, the difference between the highest and lowest reading is only +/-5%. Perfectly good for a quick check. Actual difference will be bit more since the current drops with increasing voltage.
If you shell out for a 6-1/2 digit multimeter you'll get something more controlled.
