This is just a theoretical question I have. Imagine we have a register (a reg signal in Verilog for example) and two possible inputs that have to write to that register. I am assuming all signals are synchronous to the same clock. Normally in these cases I guess that you need a multiplexer to decide which signal actually go to the input of the register. But, it is possible to connect both signals to the input without any multiplexer? I am assuming that at all times only one source wants to write to the register. I have this question because I'm wondering if it is possible to avoid using the multiplexer and thus reducing resource usage in the final circuit.
Thank you in advance
reg
does not mean that you will infer a clocked register. This was an unfortunate naming convention that was built into Verilog. Areg
is just a variable datatype. \$\endgroup\$
