Problem
I'm trying to simulate the simplest possible model for a flip-flop: two inverters connected in a circle. I'm using ngspice 31 on Arch Linux. I based my model on the CMOS SOI Inverter example (https://sourceforge.net/p/ngspice/ngspice/ci/master/tree/examples/soi/). Here is what I came up with:
SOI Flip-flop
.include ./bsim4soi/nmos4p0.mod
.include ./bsim4soi/pmos4p0.mod
.option TEMP=27C
Vpower VD 0 1.5
Vgnd VS 0 0
MN0 X Y VS VS N1 W=10u L=0.18u Pd=11u Ps=11u
MP0 X Y VD VS P1 W=20u L=0.18u Pd=11u Ps=11u
MN1 Y X VS VS N1 W=10u L=0.18u Pd=11u Ps=11u
MP1 Y X VD VS P1 W=20u L=0.18u Pd=11u Ps=11u
.ic V(X)=0 V(Y)=0
*.ic V(X)=1.5 V(Y)=1.5
*.ic V(X)=1.5 V(Y)=0
*.ic V(X)=0 V(Y)=1.5
.tran 2ps 2ns
.control
run
plot X Y
.endc
.END
This should correspond to this schematic:
I want to see how this circuit behaves under different initial conditions for the gate voltages, especially metastable ones. (I know I could use NAND gates instead of inverters to make this into an actual RS flip-flop and produce metastable states with input pulses, but I'd like to use this simplest model if possible.)
Results
The stable initial conditions yield stable results as expected:
One of the metastable starting conditions also looks fine, with an initial metastable period and a stable outcome:
The other metastable starting condition, however, produces this:
This looks different, because the voltage overshoots to 1.6 V. A longer simulation time show that it takes about 2 us to settle to 1.5 V:
Now this is still fine, I didn't expect both cases to look the same. My problem is that the values change drastically when I change the simulation step size.
So a resolution of 0.2 ps increases the overshoot to 2.6 V, and a resolution of 0.02 ps seems to push both gate voltages to 3.75 V.
I experimented with the uic option for .tran and with .nodeset, but as far as I can tell from section 15.2 of the ngspice manual, the way I did it should be the right one.
Question
I am wondering what the issue here is. Is this naive simulation model, using only initial conditions, somehow inconsistent or wrong? How can a change of simulation resolution produce such different results? Or is this just not a suitable problem for a simulation because of the non-well-behaved nature of metastable states?
11.01u
or10.99u
, or other minor incosistencies that could appear in a real-life case. \$\endgroup\$ – a concerned citizen May 4 '20 at 18:27
