I would like to measure current to a standard CO2 lasertube, which is already possible with a battery-powered digital or analog ampere meter available for cheap, but these do not allow me to read this value into e.g. a microcontroller.
I have already seen some designs based on a shunt and an isolation amplifier (http://www.ti.com/lit/ug/slau521/slau521.pdf?ts=1588611452800), but this is only rated up to 2kV, whereas my system can reach up to 25kV.
Is there another way to measure the current / voltage across a shunt resistor and isolating it?
