If you're looking for a single logic gate that provides the output you desire, there is no such thing. User @evildemonic has given you the appropriate solution for the most minimal logic gates you can have to achieve your output.
Here is a circuit with transistor logic that can be rather minimal, based on @evildemonic's answer.
At the end of the day, logic gates are made of these transistors (that behave like switches under the right conditions) so technically this is the most minimal you can design what you're looking for.
